RM European Auto Parts
Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 73
Thread: 2000 BMW 323i
  1. #26
    Feb 2015
    London, United Kingdom
    E36 328is, E87 116i
    Explains why... take it back no questions asked. You should have a Bosch unit I believe
    C217 S63 AMG S Cabriolet ( Daily )
    E87 116i with mild cams, headers, cold air intake making 136 bhp Lol (My Learning Track Car)
    E36 328i Sport ( Project in making and future race/track car )
  2. #27
    Jan 2018
    Washington D.C.
    2000 323i
    Ok. Will so tomorrow
    Sent from my LGLS755 using Tapatalk
  3. #28
    Feb 2015
    E36 328is, E87 116i
    I too thought My maf was bad one time on my e36 328.. I bought a Chinese aftermarket one off eBay and the car died as soon as I started it.. cleaned the original maf with some maf cleaner and it was good again
  4. #29
    Jan 2018
    Washington D.C.
    2000 323i
    I was originally advised to clean the maf which i did with maf cleaner. Upon doing that the car started to cut off when idle for periods longer than 20 secs. I then decided to take it to a bmw service center this morning. The tech advised me to totally replace the maf which i did which brings me to the issue i have now. I replaced it myself bc i honestly didn't have the $1000 to have them do it
  5. #30
    Jan 2018
    Washington D.C.
    2000 323i
    Im def taking the advice im receiving from you guys and it's highly appreciated
  6. #31
    Feb 2015
    E36 328is, E87 116i
    Try your stock maf again now and let us know how it is. It would be worth taking your car in to a BMW specialist
  7. #32
    Jan 2018
    Washington D.C.
    2000 323i
    Was gonna try to exchange the 1 i bought today at advanced auto parts for this bosch one
  8. #33
    Jan 2018
    Washington D.C.
    2000 323i
    Disregard. According to the advanced auto part site, the bosch maf doesn't fit my car.
  9. #34
    Dec 2013
    Chicagoland area
    EXOTICS
    Return that part, forget Advance Auto for all critical sensors.
    Choose from these options,
    GENUINE BMW OE=https://www.fcpeuro.com/products/bmw...or-13621432356
    Siemens OEM=https://www.fcpeuro.com/products/bmw...ns-13621432356
    Quote Originally Posted by WadiM3 View Post
    BMW GENUINE OE or OEM Siemens VDO
  10. #35
    Feb 2015
    E36 328is, E87 116i
    Mehh my e36 328 maf was Bosch and so is my 540 maf.. only assumed the same for a m54 323 but hey my bad!!
  11. #36
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    let's be careful of assumptions - that gets us in trouble.
    i'd follow marco's advice, and i'd also (as i already stated) look into your local chapter of BMW CCA - which is outstanding. especially if you intend to work on this car yourself.
    if all you are interested in is getting the car fixed and running (which is totally understood and reasonable - the fastest path is a quality diagnosis).
    my point is this - this is not a problem solved affordably by throwing parts. its hard for me to speculate (and that's all it would be) as to why the dealer recommended a MAF. keep in mind, you may have multiple problems and perhaps the MAF is one of them. we'd need to see data (live, running data) as well as other information before we can make a recommendation - there's just too many variables at play here. any recommendation we can make regarding actual parts or repair steps is just speculation.
    i would not operate the vehicle for long with the MAF unplugged - you can cause damage to other downstream (read: expensive) components.
    another piece of advice - FLAPs (friendly local auto parts stores) are not your friend for crucial engine sensors on a BMW. and, in reality, there's not many parts or things you want from FLAPs for a BMW. maybe washer fluid, that's about it!
  12. #37
    Jan 2018
    Washington D.C.
    2000 323i
    Advice taken regarding flaps. Gonna try recommended maf. Wish i could provide more physical evidence. Is there anything i can provide specifically that would assist you seeing my issue? The diagnostic i provided earlier came from a BMW service center/ dealership in Alexandria VA
  13. #38
    Jul 2004
    Houston, TX
    36 Cylinders
    How thoroughly did you check the intake tract for tears? (Not discounting your efforts, just want to clarify). The intake tract boots are 2 pieces and some cracks happen in difficult to see spots.
    How is CCV system?
    With engine running, what happens when you open oil cap, in detail?
    Even though the MAF can be a real issue, I think it's a red herring here.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  14. #39
    Jan 2018
    Washington D.C.
    2000 323i
    Just checked for leaks with a mechanic. We just basically popped the hood with a flashlight in hand. Gotta look up how to check ccv on YouTube. As i mentioned, don't really have any mechanical experience or the $1400 on hand that the BMW service center wanted to charge me. I'll take the oil cap off and let you know what happens
  15. #40
    Mar 2003
    St. Joseph, Mo.
    i'm aware it was a dealership - in fact, i commented on it. my recommendations still stand.....
  16. #41
    Dec 2013
    Chicagoland area
    EXOTICS
    Ok,your posted photos(post#20)reveal BMW codes that provide clues.
    In the code memory list, it contains codes for misfires(both banks 1&2),
    pre-cat oxygen sensor faults(banks 1&2), fuel trims out of range(banks 1&2).
    That info, combined with mileage of over 255k miles, leads me to suspect deteriorated components.
    Let's start with confirming easy to find intake leaks,
    by removing items #1-#6 pictured in the diagram(photo).
    Once removed, carefully check for any hidden cracks in rubber intake boots and elbows.
    Squeezing of rubber easily reveals any hidden cracks. If any found, replace.
    Since no real fault with old MAF has been confirmed, replace intake with original MAF that was removed, if still available.
    If age of pre-cat O2 sensors is known to be 255k miles-replace, as the recommended replacement life is 100k miles.
    Ideally, the codes would have been cleared from memory, so after performing these steps, and completing a short drive cycle,
    you would re-scan for new codes, to see if any return-or not, to confirm a fix.
  17. #42
    Jan 2018
    Washington D.C.
    2000 323i
    Worked a 14 hour shift today but will check for leaks tomorrow. I returned the maf i bought from advance auto parts and reinstalled the original one i already had after cleaning it again with maf cleaner. With original maf sensor attached, car runs for a cpl of mins before dying out. Sometimes i hear an odd sound comin from the engine. Sounds like a knocking sound. Only hear it when the car is running idle.
  18. #43
    Jan 2018
    Washington D.C.
    2000 323i
    Could this be the cause of my problem(s)?
  19. #44
    Feb 2015
    E36 328is, E87 116i
    I'm not sure, try to tape it up temporarily and see if you notice a difference ?
  20. #45
    Dec 2013
    Chicagoland area
    EXOTICS
    That looks like serious deterioration-Replace any cracked intake components!
  21. #46
    Mar 2003
    St. Joseph, Mo.
    Well. It’s prior to the Maf so I’m gong to say sure replace it but not likely.
    It does probably speak volumes as to the condition of the rest of the hoses.
    We cant keep playing “could it be this?” My original thoughts still stand.
  22. #47
    Jan 2018
    Washington D.C.
    2000 323i
    Ok. Thx
  23. #48
    Jan 2018
    Washington D.C.
    2000 323i
    I understand what you're saying "can't keep playing could it be this". I'm just asking questions bc i honestly don't know and unfortunately i don't have the funds ($1400) to get it repaired at a BMW service center. I respect you guys opinion (my uncle actually recommended this site to me) and that's y i listen to the answers you give. I highly appreciate everyone's responses, patience and assistance. Im not trying to waste anyone's time, I'm just asking questions. Better to ask than not to ask.
  24. #49
    Mar 2003
    St. Joseph, Mo.
    have you checked into the place marco recommended? just so you know, it will likely be less expensive than the dealer. also, that's only one quote, from one shop, on one day.
    have you checked into the BMW club chapter? just so you know, most dealers offer discounts on parts and service if you are a club member.
    we still know very little about this car - please look at the thread in this forum which asks for basic info on the vehicle. keep in mind, at this point in their life most e46s will typically need 3-4k right off the bat just to get it running right.
  25. #50
    Jul 2004
    Houston, TX
    36 Cylinders
    You are not wasting our time, do not worry.
    Do you have basic tools and some basic mechanical skill?
    I would disconnect and remove the filter box, to get a better look at the tubing nearer the engine. Take pics of those.
    This is something you can do for free.
    It's not as good a method as a smoke test, but a large vacuum leak is usually quite apparent.
    -Abel
  1. 2000 BMW 323I BLACK WITH CAMEL LEATHER INTERIOR "SHARP"
    By twinned358rx7 in forum BMW Cars For Sale / Wanted
    Last Post: 03-09-2005, 12:12 AM
  2. 2000 BMW 323I with 44,5xx Original Miles For Sale
    Last Post: 03-05-2005, 11:26 PM
  3. 2000 BMW 323i in PA, $17K
    By slilley in forum BMW Cars For Sale / Wanted
    Last Post: 09-13-2003, 07:41 PM
  4. 2000 BMW 323I, 34k - $23,500
    By pdaly in forum BMW Cars For Sale / Wanted
    Last Post: 03-25-2003, 10:08 AM
  5. FS: 2000 BMW 323i - Supercharged
    By Chupacabra in forum BMW Cars For Sale / Wanted
    Last Post: 02-18-2003, 05:42 PM
