Can anyone direct me to what the proper way to connect the bmw quick connect hoses is. I am putting the hose on to the plastic heater hoses under the intake and I am concerned that it will leak. I’m not very familiar with the procedure of the quick connect hoses. It just doesn’t seem like it is a tight connection. I am using bmw parts, but seriously a little clip holds it all together? Some YouTube videos show to leave the clip down and push it on...? Others show to press on with clip up and then press clip down? I don’t want another leak under my intake, so any advice would be greatly appreciated.
The clip holds it on, I use a bit of silicone on the rubber oring inside. The clip never lets go, screw clamps loosen slightly over time. If you notice on other hoses that have the clip when in the correct position the clip is right above the fitting.
The o-ring inside the hose connection provides the tight no leak seal,
the clip just provides a non-slip locking mechanism.
please add to your profile model and built year and post in the corresponding model subforum.My Cars 528i TA
I believe proper way is to leave the clip in position and push it on firmly until you can hear it click into place. Otherwise you may not have it fully seated before pushing the clip in.
PRICE CUT on ALL FABRICS
I've never done it that way. The clip is ALWAYS in place. I can hear it click, so I always know that it's locked in place. I spray silicone lube spray on the o-ring in the hose, as well as the part the hose is snapping on to.
I see you're a moderator, but not sure if you're a professional tech or not. I'd have to say over 12.5 years in the business, I'm sure I've disconnected and reconnected thousands and thousands of coolant hoses of all shapes and sizes. But hey, everyone has their own way of doing things, and in this situation, I don't think either way would be considered wrong.
No, I'm not a tech by profession, but service my own BMW's and have worked on countless others. In particular, M62 lower coolant hoses connecting to the water pump I've never been able to get on with the clip closed. I slide it in position then clip it and jiggle it, at which point I hear the satisfying click. Maybe because the cars I work on are old and grungy and yours are nice and new yours work "as designed" ...whereas mine, I make work
As long as it clips and clicks, it's fine
