Results 1 to 5 of 5
Thread: GM 5L40E A5S390R transmission differences 330d
    Dec 2017
    Frankfurt, Germany
    '92 750iL, '95 540iT/6
    I have a 2004 330d touring that has a bad transmission. The GM 5L40E was used in many different cars and even many different bimmers so there are many different types/codes of that tranny. Mine has the "YV" code.
    Does anybody know what these codes mean and even better, has a list of all the codes and which one can be combined? I am asking this because it is really hard to find the correct "YV" transmission, but there are many other 5L40E's from like E39 530d's and such that I could get.
    Karim
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What’s wrong with the tranny? What codes are being thrown by the tranny computer (EGS)?
    Aug 2014
    Lawrence Kansas
    2004 325XI/2008 GL320
    I believe the transmissions themselves are essentially the same, but have different torque converters with different stall speeds for petrol vs diesel.
    Mar 2017
    Norwich, Connecticut.
    E46 wag. E36 convertible
    A blue label on the pan bottom indicates GM...this one is green..Hmmm...GM blue label 5 speeds were used in mainly wagons from 99. Correct atf for the GM's is no longer available. Dexron 6, as alternative, has critics.....Not sure what you have..but know that BMW has had issues with autos.
    Aug 2014
    Lawrence Kansas
    Quote Originally Posted by Eaglesail View Post
    All GM transmissions have green tags on the side. There are several different color labels on the transmission pans indicating which fluid to use. The A5S390R GM trans was used in ALL North American AWD E46's. The A5S360R was used in a variety of coupe, sedan, and touring models. Mainly models with the "sport" package. Correct ATF is a misnomer. The viscometrics and certification for ETL are outdated because of improvements in technology. Low viscosity fluids produced now have nearly identical viscometrics for ETL when warm. The new fluids have a lower viscosity when COLD leaving them unable to be called "identical". There are a variety of fluids that are suited for the GM trans. If you go to the dealer and ask for the spec fluid for the GM trans, they will sell you a bottle of BMW Dex6. However, I prefer Maxlife multivehicle ATF.
  1. Is there a GM 5L40E (A5S 360R) Auto Transmission Guru In the House?
    By BimmerM3inGA in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 11-21-2020, 03:38 PM
  2. e39 530da (GM 5L40E) transmission fail.
    By bimmer1985a in forum E39 Touring / Wagon
    Last Post: 10-26-2016, 06:44 PM
  3. Z3 vs E39 GM 4L30E transmission differences
    By ZOP in forum 1996 - 2003 (E39)
    Last Post: 10-11-2016, 11:09 AM
  4. E46 ||| FS: E46 GM 5Speed AT Transmission A5S390R - Low Miles |||
    By aznazasin in forum Drivetrain & Transmission Parts
    Last Post: 02-22-2012, 03:09 PM
  5. Differance in GM and ZF transmission
    By rhk31 in forum 1999 - 2006 (E46)
    Last Post: 01-18-2008, 07:24 AM
