Results 1 to 23 of 23
Thread: Seeking transmission wisdom
    Jun 2017
    Denver, CO
    325xi; 740i
    I believe I am one of the only E32 owners with a torque converter lockup shudder, it is very noticeable but does not occur when cold and at full temp. I had my shop officially diagnose it, his comments were that it is my filter (not OEM, it is Febi and is very noisy). I have already ordered a filtran filter but I am seeking the common wisdom of the bunch and if anyone had any thoughts.
    New Daily:
    2011 Audi A6 Avant 3.0T prestige. 1 of 368
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    94' BMW 740i 308k miles
    Fresh 72k mile engine with all new seals. True E34 Manual Trans Engine Harness. 6spd Transmission Swap, Getrag 420G. RHD LW Single Mass Flywheel. E39 M5 Clutch. E39 M5 Shifter. Factory Car Phone. Factory 6CD Changer. Factory Electric Sunshade. Not So Factory Factory Electric/Heated Rear Seats. E38 Heater Valves. E43 M5 calipers/brakes
    Sold:
    1996 Oldsmobile Aurora; 194k miles but with a bad paint job and dented fender resulting in a payout to buy the 740i
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    I bet it is not the Febi filter, we discussed that here https://www.bimmerforums.com/forum/s...ht=febi+filter
    If it is noisy and whining, then the cause is the O-Ring on the filter is not the proper size and the trans pump pumps also air with the ATF. Second reason could be too low ATF fluid.
    I have installed plenty of Febi filters, no problem at all.
    Some years ago a Porsche Carrera owner with ZF 5HP asked for help, he had this whining after a shop made an ATF change, especially when the ATF was not at operating temperature = less volume. So besides the ATF the pump also sucked air. Here some pics in my garage http://e32b12.blogspot.jp/search/label/Porsche
    The problem was that they did not properly fill the trans and it was too low. We filled almost 1 additional liter. As he wanted to make sure, he left the car at my home and asked me to test drive it every day with cold ATF till it got to oerating temperature, this confirmed that the cause was not enough ATF.
    A valve body cleaning and rebuilt might also help http://www.bimmerboard.com/forums/posts/825438
    http://www.thectsc.com/products/valv...p30-80-39.html
    most of the parts are not required, usually needed the paper gasket between the plates and a new plastic ball
    Technicians guide, 11.5MB for download
    INDEX
    ZF 4HP-18FLE AND ZF 4HP-18 FLA DIAGNOSTIC INFORMATION
    ZF 4HP-22/24 SERIES DIAGNOSTIC INFORMATION
    MODEL “E-7” VALVE BODY WITH 5 SOLENOIDS
    MODEL “E-9” VALVE BODY WITH 4 SOLENOIDS
    ZF 5HP-18 DIAGNOSTIC INFORMATION
    ZF 5HP-19FL DIAGNOSTIC INFORMATION
    ZF 5HP-24 DIAGNOSTIC INFORMATION
    ZF 5HP-30 DIAGNOSTIC INFORMATION
    http://parts-at.ru/wp-content/upload...Tech-Guide.pdf
    Jun 2017
    Denver, CO
    325xi; 740i
    This is interesting. I can see it being too big of an o-ring when I first put the new filter in it I pushed it into place and was letting it sit a second while I grab the screws and the filter fell and gave me a shower of transmission fluid as it fell into the catch pan. I'm 90% sure the fluid level is fine, I can throw it into corners and it will maintain the gear the not fall out, I have also done 100 mph on the highway just to see if I could and the trans didn't complain. The valve body may be a problem, it has about 150k on it since the updated valve body was installed.
    Jun 2017
    Denver, CO
    325xi; 740i
    I remember I checked the fluid the other day, with the engine only being ran to pull it into the garage, I checked the fluid dead cold and without completely removing the fill plug it started streaming out which if I understand fluid dynamics it may be overfilled. I also check the temp of the trans with an infrared on the pan which I hear is about 5 degrees off of the temp sensor.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Jan 2005
    Japan
    see: BMW Transmission Fluid level check
    http://www.europeantransmissions.com...MWtechinfo.htm
    USA
    e34 540ia/e32 740il
    You need to check the fluid for the 5HP with it in a certain temp range, I forget what it is exactly but I do know that when totally called and engine off it will take less than the required amount. You need to have the car level in the air (rear wheels off the ground) and have a friend keep switching through the gears (Park, neutral, drive, reverse, etc.) when the temp is in the correct range. It will take quite a lot more fluid when you do this. I didn't have a way to connect to the trans computer for a temp output so I used a multimeter with a K-type thermocouple wire fed into the fill hole next to my hand pump tube. Once it hit temp I started filling as my buddy ran through the gears until the fluid started coming out the fill hole again.
    The febi filter is probably fine but I use the Filtran OEM one for peace of mind. Also you can un-bolt the valve body and replace the o-rings on both sides of the two valve body risers, those o-rings can be a source of transmission whine.
    Jun 2017
    Denver, CO
    325xi; 740i
    I just got the Filtran filter delivered, it feels a little heftier than the Febi but I don't have both in hand to tell. The first time I filled it I kept the engine running but just kept pumping as much as I could in, jump in run it through the gears then pump more in then back out etc... I ended up getting 5 and a half quarts into the trans which I hear is too little? I was too back and forth between the two to really check the temp with my infrared on the pan. If I put the car in park on a hill to close the garage or something it usually takes a second to two longer to engage reverse or drive indicating its low on fluid but otherwise doesn't fall out of gear. On the bright side these filters are a lot more beafy than new cars, I have an F150 Motorcraft filter on the shelf and it is half the weight of the Filtran. I have Carsoft working on a computer but that cant get into the trans live data and INPA just throws errors at me. What is the part number for the riser O-rings? Before my initial service it had a very light whine and a 1-2 shift space, the service fixed the space but brought a much worse whine.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Jan 2005
    Japan
    O-rings are shown here http://www.realoem.com/bmw/enUS/part...BMW-740i&mg=24
    Usually come with the filter kit.
    Transmission Fluid Level Checking Procedure and Application Chart https://www.bimmerforums.com/forum/s...lication-Chart
    MODEL: All with the ZF and GM automatic transmission
    SITUATION:
    Checking the fluid level may be necessary if there is evidence of a leak, a complaint related to fluid level or in the event repairs are made to the transmission.
    PROCEDURE:
    Fluid Level Checking Procedure for all Transmissions without a Dipstick:
    1. The transmission temperature must be between 30°C and 50°C before checking can begin. Use the DIS or the MODIC to determine the transmission temperature. (my hint: do it as cold as possible)
    2. The vehicle must be level and without load. With the engine running, switch on the air conditioning. This will increase the idle speed and ensure that all oil passages in the transmission are filled with oil.
    3. Step on the brake firmly, apply parking brake fully and move the selector lever through each gear position, pausing briefly in each gear.
    4. With the engine running and the selector lever in Park position, remove the filler plug located on the transmission (see picture for location). If a small stream of oil runs out, the fluid level is correct.
    5. If no oil runs out when the filler plug is removed, the fluid level is too low. Add oil until it starts to overflow.
    6. With the engine running, reinstall the oil filler plug and tighten to proper torque. (Refer to section F below for proper tightening torque)
    Jun 2017
    Denver, CO
    325xi; 740i
    I have a feeling my 500 only idle is screwing with the trans pressure and the ability to fill it to its fullest.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Jan 2005
    Japan
    switch the AC on or the blower motor and lights, RPM should go up then as the alternator has to produce more power.
    According to the workshop manual the idle speed for the M60 is 700 RPM.
    https://www.bimmerforums.com/forum/s...valve-question
    Jun 2017
    Denver, CO
    325xi; 740i
    That's what's weird, I have everything turned on yet it'll only stick to 500 it officially has no vacuum leaks and a new icv and crank case vacuum is exactly where it should be.
    Jan 2005
    Japan
    maybe one of the relays bad or fuses http://www.e32-schrauber.de/bmw/date...8_88-07_94.pdf
    Jun 2017
    Denver, CO
    325xi; 740i
    I swapped in 5 different relays all with the same pin out and diagram and it made no difference. When I go to service it again Ill have my buddy keep it at a steady 700~ rpm to try and get more in. Ive read the usual amount on a drain and fill is between 6-7 quarts so its a bit low.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Oldham UK
    '00 330i Sprt '92 525i
    Jam a piece of wood between the front of the seat and the throttle pedal and adjust to whatever rpm you want. Primitive but effective
    Jun 2017
    Denver, CO
    325xi; 740i
    I have ordered the new o-rings but I can't seem to find the check balls and gaskets separate. Thoughts anyone?
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Jan 2005
    Japan
    That means you want to make a complete valve body overhaul? http://www.zftranspart.com/index.php...=108&parent=13
    call Eriksson and tell them the details on the sticker/name tag on your trans, serial number, type and the parts number list number and as far as I understand they also sell single parts out of the complete VBK.
    This complete 5HP30VBK contains basically everything, just in case something is broken, but usually the springs and orifices can be re-used. They also offer rebuilt valve bodies http://www.zftranspart.com/index.php...parent=13&pg=1
    Jun 2017
    Denver, CO
    325xi; 740i
    I have installed a lesser mileage DME and now I have a cold idle of 700. Also with good news, most of the shudder that I was experiencing hasn't happened anymore and every shift is exactly the same whereas before it would always shift differently. Even my servotronic works exactly as it should now.
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Jun 2017
    Denver, CO
    325xi; 740i
    Just to verify from what I have read from all the DIYs, I can unplug the valve body solenoids and unbolt it and it will wiggle out? Is there anything special I need to do to align with the gear selector when I reinsert the valve body?
    New Daily:
    ----FOR SALE-----
    04 BMW 325xi 143k
    The Fun car:
    Sold:
    Oldham UK
    The insulation on the connectors on the valve body is often very brittle. So if you can reach it, you may be better disconnecting at the plug. The additional benefit is that you don't need to remember which wire goes where.
    When you reinstall the VB, make sure the [ shaped section on the end of manual shift valve (1056327173) slides back on to the lever inside the trans. You may find it easier if you put the lever in the vertical position before you drop the VB. If the valve has moved while the VB was out of the trans, you can just move it quite easily so it lines up again.
    Jun 2017
    Denver, CO
    325xi; 740i
    Felt I should update here, got the trans all apart and the valve body riser o-rings were definitely bad. Filled it back up and found it took 2 quarts more than I had drained out of it and I did not drain or clean out the valve body, I must've not pumped in enough fluid on my last service. My initial around the block drive were that it's not shifting nearly as clunky as before and is smoother than it's ever really been before.
    Jan 2005
    Japan
    Tell your shop, the Febi filters are not a problem! This is based on my experience.
    All this wrong info about bad Febi or other aftermarket filters is based on a DIY article posted in 2003 !!!! on BB https://www.bimmerforums.com/forum/s...ht=febi+filter
    The problems for all filters are the o-rings, and if one is not careful, even a original filter makes problems, plus the correct filling procedure.
    Our selection of bad and good o-rings, different filter kits http://e32b12.blogspot.jp/2012/10/tr...er-o-ring.html
    USA
    e34 540ia/e32 740il
    Quote Originally Posted by shogun View Post
    That's some good info about the O-rings! I had always used Filtran because that's what everyone said to use, but a poor seal on the O-ring would definitely cause issues.
    Jan 2005
    Japan
    Proper installation, fitting o-rings and proper filling of the ATF is all you need. Does not matter actually which filter brand. We have used a lot of these so-called Meistersatz trans filter kits from one of the forum sponsors like FCP EURO, MEISTERSATZ sounds German, actually belongs to CRP, originally named Conti Rubber Products Inc., but the filter kit is Made in China, works well, no problem.
    Then we use also VAICO, Mann+Hummel filter kits for example for the 5HP30, 5HP24, etc.
    For example coming weekend we make a trans service on an E46 320 incl. ATF fluid change, valve body overhaul, filter change and pan gasket. That E46 has a ZF 5HP19 = A5S325Z , just to give you an idea what is available based on a site in Germany for this trans, BMW p/n 24341423376
    listed as premium
    Febi Bilstein Art.-Nr.: 21023 (filter only)
    Vaico EXPERT KITS + Art.-Nr.: V20-0343 (filter, O-ring, pan gasket)
    Meyle MEYLE-ORIGINAL Quality Art.-Nr.: 3002434108/S (kit with filter, pan gasket, o-ring)
    others
    Topran Art.-Nr.: 108759 (filter only)
    Metzger Art.-Nr.: 8020014 (filter, 0-ring, pan gasket)
    Swag Art.-Nr.: 20921023 (filter only)
    There I will use the Vaico V20-0343 expert kit, as I got some on stock.
  1. 528i seeks transmission light module parts /install
    By greenmachine22 in forum Drivetrain & Transmission Parts
    Last Post: 02-07-2008, 11:27 AM
  2. seeking wisdoms of e39 wheel fitment gurus...
    By nez in forum 1996 - 2003 (E39)
    Last Post: 08-29-2006, 10:10 AM
  3. SNAFU: Seeking Unconventional HG Wisdom
    By RagnarDanskjold in forum 1992 - 1999 M3 (E36)
    Last Post: 03-02-2006, 12:09 PM
  4. SNAFU: Seeking Unconventional HG Wisdom
    Last Post: 03-01-2006, 07:16 PM
