Results 1 to 7 of 7
Thread: 2008 X3 3.0is 137k - 0-20 throttle surges and seems to lag until over 20 mph.
    Sep 2009
    Richardson, Texas
    2012 328i, X5 1994 325iC
    Very frustrating symptoms.
    From 0-20 or so, the throttle lags, then surges until over 20-25 mph, then runs fine. Idles fine, does not die or misfire. Does seem to lag some when in the lower end of power band.. 20-40 mph. No engine noises.
    I just can't tell were to go with this. I do some wrenching mainly on e30s, e46s, e36s.. etc. but this 'feel" like a tranny slip, but no lights or other indications of trans problem.
    Any ideas?
    Aug 2012
    Kansas
    2000 m roadster 2010 x3
    May have a vacuum leak. You could have a mechanic smoke test it for any leaks or build one and do it yourself. Do you know anyone with a bmw code reader ?
    Sep 2009
    Richardson, Texas
    UPDATE: Last night, the SES light comes back on, the car starts missing, idling bad and making a loud, whining noise in the engine, worse at idle, and never stopped. Had to drive home and barely made it. Lack of acceleration, missing, etc.
    Camshaft/ crankshaft sensor? But what was the weird noise? Even more confused now.
    Dec 2013
    United States
    2003 BMW 330i Sedan
    The vacuum leak just got a lot easier to find... check yourpcv system or possibly the big hose on the rear of the valve cover.
    Sep 2009
    Richardson, Texas
    CCV system?
    Aug 2012
    Kansas
    A bad ccv will make it smoke too and use oil. Go to the z3 forum and look for the z3 diagnostic thread. You can download inpa software to a laptop and have a factory code reader once you get the 20pin cable
    Sep 2009
    Richardson, Texas
    I resolved the problem. The air duct from the air box to the intake throttle body was disconnected from the throttle body. ALL that unmetered air now measured!!
    Is like a whole different vehicle.
  1. Replies: 3
    Last Post: 01-09-2014, 05:55 PM
  2. Replies: 7
    Last Post: 06-17-2007, 06:37 PM
  3. FS: 2004 BMW X3 3.0i 7,800 mi, CPO to 100K
    By stream41 in forum BMW Cars For Sale / Wanted
    Last Post: 05-19-2007, 12:20 PM
  4. 06 X3 3.0i Performance Chips
    By jdcrosstown in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 04-04-2007, 06:55 PM
  5. 1997m3 vs. X3 3.0i
    By m3outtanowhere in forum Kill Stories
    Last Post: 10-16-2006, 10:14 AM
