Results 1 to 11 of 11
Thread: Supercharger Vacuum Line Routing
    NJ
    96' 328is, 86' 325e
    Hey All,
    I've searched a lot for diagrams and threads regarding vacuum line routing but i haven't been able to find anything definitive. I just purchased a 97 m3 with a RMS Stage 2 SC with an AA tune.
    I drove the car home 623 miles from Michigan with no issues besides the tune not being the best and running rich. I stayed out of boost the entire time until i was home and once i did get home i got on it a bit. I parked the car and came out a little while later to take it for a spin and that's when it developed a high idle
    I noticed there was no vacuum line plugged into the bypass valve and i couldn't find anything that was loose around it. I checked the vacuum lines under the manifold and it seems like its routed incorrectly.. The current setup is as follows - The vacuum nipple under the M50 manifold closest to the firewall, has a short vacuum line going into a plastic T, one end is going under the manifold somewhere to the FPR i'm assuming. The other end is going into a check valve that goes into another plastic T. One end of that T is going into the nipple under the manifold, right behind the TB and the other end of the T is going to what looks like the Purge Valve solenoid.
    On a supercharged S52, what's the correct routing path for these lines? I should also add it looks like the secondary air pump is still there but the other emissions stuff has been deleted since the car has after market headers.
    Thanks in advance guys!
    NJ
    96' 328is, 86' 325e
    Bumo
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    RMS might be able to help you out. I think Osh is the guy's name over there.
    '98 RMS stage 2+++++(491whp/390tq VAC cams, CES Cutring-9:1, Built blower, Meth etc)
    '09 Saab 9-5 Combi 5mt 1 of 1(Built Motor, Brembos, LSD, the works!)
    '22 Cadillac CT4-V BlackWing 6mt
    '22 Cadillac CT4 2.0T Sport AWD (wife's)
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    The bypass valve needs a line from the intake manifold, but it can be a shared line (one with a tee). No check valve in the path to it. It is the purge valve that needs a check valve before it since you don’t want to pressurize your gas tank when in boost — you just want to suck vapor out when in vacuum. The hose you describe where one intake manifold nipple has two tees in it and then returns to another manifold nipple does not make sense, so someone who did not know what they were doing did it or was trying to cover up another issue (maybe a bypass valve with a torn internal diaphragm). Instead, one nipple could have a tee and feed the FPR and the bypass valve. The other could have a check valve and go to the purge valve. Blow through the check valve to see whicc direction blocks pressure so you orient it so pressure can it reach the purge valve.
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    Dinan gave the bypass valve it's own dedicated line tapped off the brake booster. Here are both shown.
    Check valve for the purge valve. Comes off the nipple on #9 http://www.realoem.com/bmw/enUS/show...diagId=11_1124
    Since you have no secondary air pump, there is no "correct" vacuum routing. It's really quite simple.
    FPR needs vacuum
    Bypass Valve needs vacuum
    Tank vanting needs vacuum (and check valve orientated to keep boost from flowing out)
    --- if applicable; Secondary air pump (and check valve orientated to keep boost from flowing out)
    Here's an M50 manifold I added ports to (and used an aluminum manifold adapter without the nipple shown on the diagram link #9)
    If you have any other valves for the oil separator drain or oil separator venting then you will need to supply those (Should only be a Dinan thing).
    NJ
    96' 328is, 86' 325e
    Awesome, thanks for the responses everyone. I plan on going out tomorrow and rerouting the lines as you guys described. I'm assuming if reworking the lines doesn't fix my idle issue, I should then remove the aftercooler and get to the idle control valve. It's got a brand new Porsche MAF so I know it's not that.
    Also just curious the line from nipple #9 that goes to the check valve and then to the purge valve, If that's T'd off after the check valve, besides the purge valve, where would the other side potentially go? Secondary air pump? If that's disconnected, anything else require vacuum? The digital boost gauge seemed to work fine and the valve cover has the plastic nipple that only has one port for the evap but no smaller vacuum port.
    NJ
    96' 328is, 86' 325e
    So I fixed the vacuum lines today but no dice, car still has a high idle but now at start up it's 900 idling a little rough but once you give it some throttle the idle sits at 1500 2000. I took the car for a drive and it was alright, had power buy felt inconsistent.
    My next guess is the idle valve though I disconnected it and it really didn't do anything. My buddy has a smoke machine I can use so I plan on doing that tomorrow
    Jan 2006
    Oakhurst, CA
    Did you drive it around to give it time to adapt? If your bypass valve was not hooked up to vacuum it was compensating.
    NJ
    96' 328is, 86' 325e
    I took for about a 15 20 minute drive
    Jun 2005
    New England
    It seems like the PO had an issue and could not figure it out and bypassed the bypass valve, not that it was necessarily the problem. Once sorted out a forced induction car is great but a lot of owners don’t really know what they are doing and unfortunately some shops don’t either and take large quantities of your money trying to figure it out. Best to take it to someone who knows these cars even if you have to drive a long distance.
    Aug 2009
    Rochester Hills MI
    98 M Rdstr
    Again, you have BimmerClinic+MaxPSI not far from your house.
  1. Exhaust Flap - Vacuum Line Routing
    By morzada in forum 1991 - 1999 (E36)
    Last Post: 01-04-2016, 02:41 PM
  2. BMW E53 X5 4.4 Vacuum Line routing
    By EuroImports in forum 1999+ X5, X6 (E53, E70, E71, F15, F16, G05, G06)
    Last Post: 09-23-2012, 01:21 PM
  3. AMS-500 Boost controller Vacuum Line Routing
    By MikeE36 in forum Forced Induction
    Last Post: 12-22-2011, 11:29 AM
  4. Vacuum Line routing for gt35r
    By MPerfect in forum Forced Induction
    Last Post: 11-17-2006, 01:30 AM
  5. Vacuum line routing
    By M3 Muscle in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-28-2005, 10:55 AM
