Results 1 to 4 of 4
Thread: 'vert rear side window "sluggish"
    Mar 2005
    italy
    Z3 M44 roadster 1997
    [SOLVED]'vert rear side window "sluggish"
    I've asked in lot of forums but this is a "strange" behaviour for rear side mirror: the common fault for that component is related to regulator that cracks and stops the window.
    In that case, it seems "stopped" by something rubberish: spraying some WD or spray lubrificant it get well, when it dries goes to initial point. Seems that there are some parts that makes a lot of friction with the glass causing it to operate sluggish. If you see at the end of the going down operation, when the "braking" behaviour ends the mirror goes down veru fast (you can hear a "thunk!!" in the clip above).
    Same behaviour going up.
    Some suggestion?
    miss ZUKU!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Try a silicone lube. If that doesn’t do the trick you’ll have to pull the interior trim panel and the vapor barrier to see what’s going on. Make sure you replace the vapor barrier properly or else you’ll get water intrusion.
    Mar 2005
    italy
    CABRIO is slightly different I think...
    miss ZUKU!
    Mar 2005
    italy
    SOLVED!
    the issue is the rubber seal that has a "furry" surface: it went away and the rubber was in firm contact with the window black part that is "ticker" than the glass itself.
    I removed the seal: motor smooth and fast. So I solved bending a little the metal part that holds the seal on the interior and removing a part of the seal -hidden in the window's hole, so not visible from the exterior- to make room larger.
    VOILA!!! now window is perfect!
    https://www.youtube.com/watch?v=D28Ptp9p0w0
    miss ZUKU!
  1. rear side windows... tinting how do they come out ??
    By pimpedbmw in forum 1991 - 1999 (E36)
    Last Post: 12-03-2003, 06:20 PM
  2. How do the rear side windows come out?
    By Bejeezus in forum 1992 - 1999 M3 (E36)
    Last Post: 10-22-2003, 09:52 PM
  3. re: electric rear side windows
    By forcefed in forum 1992 - 1999 M3 (E36)
    Last Post: 04-22-2003, 08:25 PM
  4. (E36) Coupe Power Rear Side Windows
    By CABimmer in forum 1991 - 1999 (E36)
    Last Post: 07-24-2002, 04:52 PM
  5. (E36) Coupe Power Rear Side Windows
    By CABimmer in forum 1992 - 1999 M3 (E36)
    Last Post: 07-24-2002, 02:22 PM
