1999 BMW M3
Silver on Black
https://drive.google.com/open?id=0B1S6Axv0SJBmT2dqV0JPMWpHOW8
(Google Drive link with photos before and after cage + interior redo)
Carefully maintained and tastefully modified with zero expense spared, All receipts and maintenance performed and documented. Has only ever been worked on by OMG Motorworks and Maximum PSI. All Original body panels with VIN tags in tact.
Engine (modifications) / Transmission
M50 Manifold swap
24# injectors
Porsche 803 MAF
3.5inch intake
Secondary air pump delete
PCV delete + Oil catch can
ASC throttle body delete
Custom fabricated Long tube headers (Moonlite MotorWerks)
Custom single 2.5inch exhaust / V-banded sections (magnaflow resonator + test pipe sections included) / 2.5inch Blox racing turndown muffler with 3inch tip
Titanium Valve Springs
New seals / gaskets / head redone by MaximumPSI
Mishimoto Radiator
Clutch fan delete
SPAL Fan
Hardmotorsport Oil Cooler kit
Oil Pan seal replaced + Oil pump nut tacked and safety wired
Upgraded 180amp Alternator
UUC DSSR
Custom Active Autowerkes tune done by Nic Nunez
Suspension / Chassis
KW V1 Coilovers
Rogue Engineering Rear Adjustable Control Arms
Rogue Engineering RTABs
Rogue Engineering Reinforced Rear Shock Mounts
OEM Rear Differential and Subframe Bushings
OEM Front Control Arm Bushings
AKG Transmission Mounts
OEM Front Shock Mounts
Revshift Engine Mounts
Motion Motorsport Aluminum Underpanel + Radiator Baffle
OEM X-brace
Guibo and CSB replaced
Brakes / Wheels
Rogue Engineering SS brake lines
Hawk HPS pads
OE Rotors
Motul RBF 600
Full size Contour Spare wheel
17x9 et30 Apex Arc-8s with Michelin Pilot Super Sports
MotionMotorsport Stud Conversion
17mm Spacers in the rear
12.5mm Spacers in the front
Exterior
Hardmotorsport V1 Fender Flares
Extreme Dimensions LTW replica spoiler (OEM spoiler included with sale)
Hardmotorsport tow hook
Hardmotorsport Canards
DJ Auto Projector Headlights
18inch LED Bar
Comes with factory spoiler
Comes with Factory Shifter assembly
Interior
Sparco Sprint seats
Sparco Steering Wheel
Hardmotorsport Door Panels + Sparco Door pulls
Schroth 4-point ASM harnesses
Leather Z VDO gauge kit (Oil temp / pressure / water temperature)
IRP V3 shifter
Aluminum Cluster Rings
4-point Bolt in Roll cage (painted white)
AEM EUGO Wideband
Hardmotorsport Rear Deck Lid delete panels
Hardmotorsport Aluminum Spare wheel cover panel
2M shiftboots Hurricane shift boot and e-brake boot
Electronics
JVC KD-R770BT Headunit
JVC CS-DR620 Speakers
Hardwired for Blackvue Dashcam
Hardwired for Valentine V1 Radar Detector
Car is located in Brooklyn, NY and is available to been seen at any time.
Price - $16,500
You can contact me at 347-276-8787
Call or text is fine.
Looks like a very fine car there. I’m however curious about your thoughts on the IRP shifter. Likes, dislikes. Do you have any pics of the install perhaps?
Good luck with the sale
Thank you!
As far as the IRP shifter goes, I love it. The build quality is very good, shift feel is great and very notchy bolt action rifle like. My biggest concern was that the throws would be too short and it would be difficult to get used to, but that isnt the case at all. I have it paired to a UUC DSSR and the combination simply cant be beat for the price.
Awesome. Thanks!
I actually have the UUC Evo 3 short shifter with the DSSR now so I’ll pair that up to an IRP shifter very soon.
Thanks again.
I was wondering if there was any cutting of the center console required for installation
