Results 1 to 22 of 22
Thread: H&R springs still no good?
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    I’ve read plenty of older posts from 2010-2012 about the rear H&R springs being too weak. I also saw a lot of people saying they run them with no issues, so I don’t really know what to believe. I’ve found a lot of people on these forums tend to just regurgitate wrong information. Is the consensus still that they should be avoided or has H&R reworked them since then?
    Western Coastal CT
    E31s
    Interesting question, and probably worth a discussion with the Company to see if they made any changes in light of the criticisms from the E31 crowd...and if they did so, how one identifies the newer product from the old which presumably is important given the likely low velocity of dealer inventory turnover.
    It would also be intersting to hear from anyone who has installed the rears recently to get fresh input...
    SteveCT
    E31s
    F30 daily driver
    Nov 2008
    NYC
    91 850i-95 850csi- 94 85
    I dont know if HR made any changes but i have them in my 850I and they are to low and soft I have replacement non HR waiting to go in.
    Indianapolis, IN
    93 850Ci, 09 Caddy SRX
    Quote Originally Posted by G8nightman View Post
    Ditto!
    1993 850Ci.....18 years & 165,000 miles and counting!
    Dec 2007
    Dallas, TX
    '93 850Ci- Daily Driver
    They were too soft then, and they are still too soft now.
    '93 850Ci - Mineralweiß Metallic
    2001 740iL - Titansilber
    ALPINA B7 -Alpinweiß III
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Dang, that sucks. I guess I’ll have to source something else.
    The OC, CA
    95 840Ci
    I ran them on my prior 850. They sit lower than say the Eibachs. They stance looks nice if you like it a little lower. When combined with the Bilstiens (because these are so stiff) they provided an acceptable ride. The balance might be a little off, but unless your going to track your car, I think they are fine. You need to look at your spring and shock combination and usage before deciding which is right for you. Many are also using the H&R front in combination with something else in the rear (cut OEM or MTech CSI)
    Current
    95 e31 840 Ci (Auto) Orient Blue 61k
    11 e90 328i Space Gray
    18 F15 X5 35i XDrive White
    Past
    00 e38 740 i (Auto) Titanium Silver
    94 e31 840 Ci (6 speed conv.) Avus Blau (This car was Awesome!)
    03 e46 325 Ci (Auto) Jet Black
    91 e31 850i (Auto) Diamond Black, Yes, two!
    00 e39 528i (Auto) Jet Black
    92 e36 325i (Auto) Laguna Green
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yeah I’m looking at the KAW Springs with bilstein sports now
    San Ramon, CA
    850Ci, M5, Model-S P85D
    Quote Originally Posted by killian665 View Post
    As most are aware this is a topic that goes back to the RoadFly days and I have weighed in on this topic since I upgraded my 850 suspension in 2005.
    I have done the research, home work and the H&R could care less what the E31 owner thinks about their springs, I know because I talked to them in 2005.
    Bilstein shocks are an issue because they are a High-Pressure gas shock which increases the ride height, something we are trying to reduce, the actual shock rates may not be compatible with the springs installed and Bilstein compression rates typically cause a very harsh ride. Hence those that are most happy with Bilsteins have had them re-valved.
    The aftermarket spring sets (H&R, Eibach, etc.) are problematic for the E31.
    The actual reason for their failing of a weak rear spring is IMHO due to the equation used to calculate the installed spring rate for the E31's rear multi-link suspension.
    The typical coil-over suspension (front of E31, F&R E32, E34) is a simple calculation with the installed spring rate being equal to over 90% of the actual spring rate.
    However, the E31 rear suspension requires the mathematical squaring of the springs installed suspension ratio of .60, therefore the calculated/measured installed spring rate is a measly 36% of the actual spring rate.
    I would suggest that BMW offers the stock, Euro M-Sport and CSi spring combination that provides reliable/predictable rates for best performance.
    If you want something lower in the front? then use the H&R front with the BMW Euro M-Sport rear spring.
    If you want a stiffer ride than the BMW CSi springs offer? then the Eibach front with a custom cut Eibach stock spring (thelongride post: http://www.bimmerforums.com/forum/sh...imited-edition).
    I suggest you get the best BMW or anyone has to offer by using the Euro M-sport Springs, rear M-Sport shocks with a Koni front adjustable cartridge installed in the OE front strut.
    See Hypers Post: https://www.bimmerforums.com/forum/showthread.php?1995992-Koni-front-inserts-revisited&highlight=Hyper+Koni
    If you want to study what this is all about please review the Pitch/Bounch motion location center information I put together in 2013.
    Attached Files Attached Files
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Wow what an enormous pain in the ass that looks like
    Jun 2008
    SF Bay Area
    Supercharged 850ci
    Dinan stage 3 springs + TRW shocks = very very happy.
    Iceland
    BMW 850
    Running TRW plus eibach now. Happy
    Refurbishing CSI springs that will go in and should make me super happy
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Coming across the m sport springs is next to impossible. I wish someone just made adjustable coilovers.
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    All the spring info you need is right here...
    http://mwrench.com/Whitepapers/Mwren...ing%20Dyno.pdf
    '91 850i 6sp (mint) (sold)
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Right but all that was done 11 years ago. Was just asking if anything had changed. I’d seen so many bad things said about the H&Rs I thought maybe there would have been a change by now.
    Sep 2010
    Finland
    bmw 850i M-tech
    Quote Originally Posted by Fatandre View Post
    How can you refurbish springs ? They are, what they are.
    Iceland
    BMW 850
    Just sand them and paint
    Jul 2015
    Melbourne, Australia
    1994 840Ci - M60, 6MT
    I may have a set to sell soon...
    but I'm a few oceans away.
    San Ramon, CA
    Adjustable coilovers do nothing to solve the Pitch/Bounce motion center location problem caused by a set of springs with a mismatch of the front & rear spring rates.
    Having the wrong front to rear spring rate ratio is like having a stock spring on one front wheel and an H&R spring on the opposite front wheel. So then, you just use adjustable coilover strut to correct the ride height between the two sides.
    Sport shocks nor swaybars help either.
    Yes, you probably can't purchase M-Sport springs from the BMW Dealer as they are in the BMW Euro parts Catalog, however that I'm aware ECS Tunning can get them for you:
    Front M-Sport springs p/n: 31 33 1 138 735
    Rear M-Sport springs p/n: 33 53 1 138 738
    Rear M-Sport shock absorber: 33 52 1 137 474, or option CSi rear shock with Koni Front strut cartridge installed.
    Rear CSi shock absorber: 33 52 2 227 258
    https://www.ecstuning.com/Search/Sit..._53_1_138_738/
    You could also check Schmiedmann. They shipped me Euro parts I could not get anywhere in the US.
    https://www.schmiedmann.com/
    Dec 2007
    tucson az
    91 e31 92 e31
    I have a set of rear eibachs and bilsteins available
    less than a 1000 miles
    i put my EDS BACK ON
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    Yeah I’ve ordered a bunch of things from Schmiedman, most of it 6 speed parts. My problem with the available spring options is that they still sit really high but I don’t want to hack up a set of CSI springs or something rare like that to get the height I desire. I wish air suspension wasn’t so expensive lol.
    And by wanting adjustable coilovers I meant just some with proper spring rates that I can adjust the height of. My E39 I was able to get any spring rate I wanted. The suspension on these 8s isn’t too dissimilar from an E36 I don’t see why there isn’t something like that available yet. Proper spring rates with an adjustable perch in the rear and the front is like any other cartridge set up.
    Also I’ve seen a lot of people suggest getting the rear CSI bump stops too for any kind of lowering spring, I’m assuming that’s because the stock one is too tall or something for aftermarket springs?
    Jun 2012
    Woodstock, GA
    2001 BMW 540i6
    What if I had my stock springs shipped off to someone like Swift that makes custom springs and just had them make me some that gave a 1 1/2 inch ride height drop and were 30-50% stiffer than what I have but within the same front to rear ratio so that way it’s still a balanced for the 8 just stiffer and lower?
    Like measure what they are for the front, new fronts be 30% more than stock and do the same for the rear. No change in front to rear ratio just stiffer.
  1. Replies: 5
    Last Post: 04-16-2013, 12:42 PM
  2. 2nd to 3rd gear...no good..help!
    By steve m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 02-04-2003, 10:57 PM
  3. Reiger no good...
    By Walden in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 01-23-2003, 06:06 PM
  4. Replies: 26
    Last Post: 12-07-2002, 11:52 AM
  5. Story for those bored at work...Snow + M3 = no good...
    By NoSoup4U in forum 1992 - 1999 M3 (E36)
    Last Post: 12-05-2002, 01:26 PM
