E39 540i 6 Speed manual swap kit - Getrag 420G
This is a manual swap kit for post 2000 (facelift) E39 540i sedans/wagons. It comes with a Getrag 420G transmission, Transmission crossmember, manual pedal set, shifter assembly, rebuilt driveshaft (brand new center hangar bearing), used pressure plate and clutch. The only thing missing is the flywheel which i recommend you get new. I also recommend changing the clutch since it will be a pain replacing it later. The shift shaft seal seems to be leaking so I'd recommend changing that too as it is a 6$ part, part number 23121228493 . The donor car was rear ended so I had to scrap it. It drove like a dream before that, no problems in any gear. Note that i am not including the m-sport shift knobs as I no longer have them. I am including a standard non-msport 6 speed knob.
I am looking to get 1450 USD total. Includes shipping anywhere within the continental united states or Canada.
whoops, i just realized i made this in the wrong thread. can a moderator move this to the drivetrain section?
Contact me if you're in the GTA, Ontario area for G.A.S master timing kit rental
