Results 1 to 3 of 3
Thread: Throttle lag
    Jan 2018
    Fond Du Lac, wi
    2011 328i
    Throttle lag
    I've had my 328i for 2 years. I put a sprint booster on it a year ago and it's somewhat improved. I drive it most of the time is DS mode with the Sprint booster in green mode. It's mostly better, shifts really high once and a while but that's not that bad. The worst part is the long lag when rolling through a stop sign (or an action like that) and stepping on the gas........wait.......then it hits. I do the throttle reset once a week or so.....
    I'm thinking about the bms juice box, might be better? Or Autowerks?
    It could be so much better...... Once and a while I drive it in normal mode with the Sprint booster off...... I can't believe they sold these cars like that.....
    Is there a better fix out there? I love a lot of things about this car, not the fueling.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I’d check to see if there’s an update to the engine computer (DME) software. No, you don’t have to go to a dealer. A well equipped independent shop that specializes in bimmers can tell you if the software is up to date. Also, did you scan the DME and the automatic tranny computer (EGS) (if it’s a automatic) did codes?
    Jul 2004
    Houston, TX
    36 Cylinders
    An engine control module tune from a knowledgeable tuner will improve it all. Adding devices like sprint booster are just bandaid type fixes to modify the signal in the engine ecu, but the ecu is the source of the programmed lag, purposefully for 'comfort'... Comfort, because it's what consumers asked for.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
  1. Throttle lag
    By Jaybird180 in forum 2004-2010 (E60,E61)
    Last Post: 03-28-2008, 11:09 PM
  2. slight throttle lag
    By darth510 in forum 1991 - 1999 (E36)
    Last Post: 01-25-2007, 07:19 AM
  3. strange throttle lag problem
    By More&Faster in forum 1983 - 1991 (E30)
    Last Post: 12-14-2006, 11:58 AM
  4. 95 325i Throttle lag
    By 1jcplnd in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-02-2006, 04:20 PM
  5. Idle problem, Throttle lag....
    By lachssilberbim in forum 1983 - 1991 (E30)
    Last Post: 08-17-2005, 08:02 PM
