Hey guys! Last week I was lucky enough to pick up my first e30. It's a 1987 325e, I've been taking it for a spin around town basically every day since it was purchased last Saturday. I have began to notice that there is a very weird grinding sound coming from inside the engine bay. The sound usually begins when it starts to drop below 1500 RPMs (when i come to a stop) and continues pretty much up until I get going again. For the handful of days I have driven it, I've only heard the sound twice (on two separate days). The timing belt/water pump replacement has been made according to the previous owner; however, I am going to replace them again because I'm not sure how long ago they were replaced.
I have a bunch of maintenance parts on the way (spark plugs, oil filter, fuel filter, etc...), but I'm pretty sure those things aren't gonna solve the problem. If any of you guys know what it could be, please let me know!
Ah, an eta! I owned a 1985 325e for 15 years and ~175k miles. He was a tough little bugger. Can you reproduce the noise when the car is sitting still? If you can, take a video of the engine (with sound!) and post it to youtube. Then paste the link.
removing the accessory belts will help narrow down the source. Spin the alternator by hand and listen, check the water pump for wobble, etc.
Run the engine briefly without the belts and see if the noise persists.
I've seen M20s with timing belts rubbing that made noises I imagine similar to what you are describing too.
