NOW SOLD!!!
I am selling the following components, the parts were test fitted on an engine, only to be removed before the engine was installed in the car. The components are essentially brand new:
Timing Chain - Iwis (OEM) 11311741746
Cylinder Head Oil Check Valve - Genuine BMW 11121706921 (x2)
Timing Chain Guide Upper - Genuine BMW 11311435028 (x4)
Oil Separator (X5 only) - Genuine BMW 11151705237
Valve Cover Seal Washer - Elring 11121437395 (x16)
Valve Cover Seal Washer - Elring 11121721879 (x6)
Valve Cover Gasket Set Left - Elring 11120034105
Valve Cover Gasket Set Right - Elring 11120034104
Distribution Housing Gasket Left (Cylinders 5-8) - Genuine BMW 11361705579
Distribution Housing Gasket Right (Cylinders 1-4) - Genuine BMW 11361705578
Distribution Piece (Cylinders 1-4) - Genuine BMW 11361433660 = solenoid shown in picture not included (unless for additional cost)
Distribution Piece (Cylinders 5-8) - Genuine BMW 11361433664 = solenoid shown in picture not included (unless for additional cost)
Water Pump Gasket - Genuine BMW 11511731372
Timing Chain Guide Left Lower - Genuine BMW 11311745406
Timing Chain Guide Rail - Genuine BMW 11311741777
Timing Chain Guide Rail - Genuine BMW 11311741236
Timing Chain Guide Rail Green O-ring (Seal Ring) - Genuine BMW 11141736758
Timing Cover Gasket Set Lower - Genuine BMW 11141436978
Camshaft O-ring - Genuine BMW 11311705512 (x6)
Gasket Ring - Genuine BMW 07119963355
Timing Cover Profile Gasket (Cylinders 5-8) - Genuine BMW 11141741128
Timing Cover Profile Gasket (Cylinders 1-4) - Genuine BMW 11141741127
Beisan Systems Rebuilt M62tu Vanos Units (x2)
Timing Chain Tensioner Lower - INA 11317531813
Oil Level Sensor O-Ring - Elring 12611744292
More pics, as I can only attach 5x pictures per post:
More pics:
Not every little part is shown, just the major ones to shown their practically new condition. Also have most of the fasteners needed for most of these parts & can provide pictures of the minor bits if required.
BUMP for a significant price drop!
What is the price drop? very interested thank you
