Good evening everyone,
I am thinking about buying a 2005 645Ci coupe and this will be my third BMW. I've always fond of the M-Parallel wheels on the e38 and I would like to ask if the OEM e38 M-Parallel wheels will fit directly without modifications on the e63 coupe. I currently have a e39 and I know the e38 M-Parallel wheels do not fit the e39 without modifications. Any tips and suggestions will be great.
Furthermore, if any members have any photos to share of their e63/64 with M-Parallel wheels, I'd appreciate it greatly. Thank you.
Hi,
The E63/4 is a fairly large car and 18's will and do look small. There might also be an issue with brake caliper clearance, even if the stock E63/4 wheels are 18's. There's also the aspect that on the E63/4, Style 37's just won't look very good. I guess someone has tried and knows more and there might even be pictures. However, it's more likely no one's tried, so you can either find a set of the E38 style 37's and try or, look at other more suitable wheels, 19 or 20 inch!
Cheers, Dennis!
Hello, my brother wants to put a set of e38 mParallel wheels on a 2010 535. is the offset even close? is the hub the same. bolt pattern is the same @5 on 120
