Results 1 to 17 of 17
Thread: Overhead Check Panel Question
    Athol, MA
    87 M6, 90 325iC, 89 iX
    My Brake light bulb out warning light is constantly lit on my overhead check panel yet I don't have a brake light that is out. Will this light also light up if there is an issue with one of the brake pad sensors? Just trying to figure out why or what is triggering this to come on???
    "Life is too Short to drive boring cars"
    1986 325E
    1989 325iX (Long term 5-speed/refresh project)
    1993 MB 300E
    1995 MB E320
    2000 Audi TT (Winter AWD snow beast)
    2007 Porsche Cayman S (Summer car)
    2009 VW Touareg
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    No, the brake pad wear sensor is different, you'll find that out one day. I had the same issue you did long time ago, I think I removed the brake light one at a time, cleaned them and firmly reinserted. That fixed it. If that doesn't do it, take 1 bulb out at a time and replace with a new. Maybe that will fix it. If not black tape is your friend. I really, really despise BMW warning sensors!
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    Did you check the high brake light? Is this the convertible?
    "Howdy, Folks!"
    Athol, MA
    Not a vert, it's my 86 325e. The third brake light works fine. I'll try removing, cleaning and reinstalling my bulbs.
    1986 325E
    1993 MB 300E
    1995 MB E320
    2009 VW Touareg
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    also, the sensor are made to read resistance off the lights that have a silver base, not the brass base bulbs. those will make the light come on constantly
    No e30s again.
    Athol, MA
    That's good to know. I will have to look and see what type of bulbs I have.
    1986 325E
    1993 MB 300E
    1995 MB E320
    2009 VW Touareg
    Athol, MA
    I was so hopeful when I checked the bulbs and found one was the brass base vs the silver base. My hopes were quickly dashed when I changed it out for a silver based bulb and the overhead brake light out indictor was still lit. On the bright side, all the brake lights work at least. And yes, I even checked the third brake light bulb.
    Could it be an issue with the check panel itself?
    1986 325E
    1993 MB 300E
    1995 MB E320
    2009 VW Touareg
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Not likely. The way it detects a burned out light is as follows. The sensor "relay" for each lighting circuit is a coil wrapped around a reed switch. If enough current is running through the wires, a big enough magnetic field is generated to flip the reed switch on. In the case of the brake lights, you have one in the high stop light housing and one for each brake light inside the check relay. These are all in series. If these 3 switches don't turn on when the check control sees the brake pedal pressed, it sets the light.
    Now if enough current is not flowing, one of the reed switches won't close. Now if you know ohm's law (E=I*R or I=E/R) then you know as resistance goes up, current goes down. So basically if there is too much resistance in any of those location your check panel will light. Check all your bulbs again. It might be a good idea to simply replace them all including the high brake light. The reason I asked about the convertible is a known issue with the high brake light's circuit board. There's a similar circuit in the regular cars. Make sure the connectors aren't corroded.
    "Howdy, Folks!"
    Sep 2014
    KS
    e24e30e36e39e90
    The brake switch is also worth checking.
    https://www.r3vlimited.com/board/sho...d.php?t=260144
    Also check the grounds back there, ground points can become corroded and cause false warning lights.
    I had a bulb that still worked, but it must have had a loose filament because it was randomly tripping the panel light. Of course replacing all bulbs would fix that.
    Good luck.
    Athol, MA
    All new bulbs didn't fix the issue. I will be checking the brake switch next or maybe just replacing it.
    1986 325E
    1993 MB 300E
    1995 MB E320
    2009 VW Touareg
    Dec 2005
    No e30s, again :(
    that's weird. it sounds like you might have a larger issue. I guess we will see how that switch goes
    No e30s again.
    Dec 2019
    Australia
    E30 323i coupe
    Hi all,
    My over head panel doesn't light up or work. How can I fix this?
    Cheers
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Count your blessings. I can't think of any info that panel gives that is useful, or you can't find out in a practical manor. You get many false reading you chase your tail trying to find out why the sensor is giving you a warning. On an old car, you should checking for these things on a regular basis.
    Dec 2005
    No e30s, again :(
    Thats true. It looks cool but is all stuff that should be checked regularly anyways
    No e30s again.
    323i E30's Avatar
    323i E30 is offline ⅂!ʈө !ƨ l!ʞө ɐ ʇөlөbµouө
    Jan 2013
    Europe
    M52 E30 touring & E91
    I like it
    Checking my overhead panel is so much lazier and quicker than having to check things outside of the car, and it has always been accurate on all of my E30s (except for my oil light with this one, since the engine swap).
    A light that will warn you of your oil level being at minimum is without a doubt a useful feature though.
    Yes, you should check it regularly, but not everyone always does so.
    ^ true story
    D̶i̶b̶s̶ ̶o̶n̶ ̶t̶h̶e̶ ̶E̶2̶1̶
    Jun 2008
    PIttsburgh PA
    13 128i cabrio, 84 325e
    I know the OP car isn’t a vert but I had to replace the small circuit board in the third brake light. I replaced it with the one from a non-vert and now the sensor works fine. On when started and off after touching the brake.
    Oct 2005
    Atlanta
    1991 325is
    My comment probably won’t be very helpful, but I will state it for the sake of covering all the bases.
    The cover for your lights located in the trunk has to be tightened down properly or it could trigger the sensor on your overhead panel. As I drive my vehicle, it occasionally works loose and my panel triggers a light problem, but when I tighten the cover the warning is removed from the panel.
  1. Check panel question.....
    By nadodude in forum 1983 - 1991 (E30)
    Last Post: 05-17-2009, 01:10 AM
  2. overhead check panel
    By stegosaurus in forum 1983 - 1991 (E30)
    Last Post: 08-28-2008, 10:16 PM
  3. Retrofit : Overhead Check Panel into 318is..?
    By dude8383 in forum 1983 - 1991 (E30)
    Last Post: 07-14-2008, 12:47 PM
  4. Check panel question
    By 84E24 in forum 1976 - 1989 (E24)
    Last Post: 04-22-2007, 01:30 AM
  5. Check panel question
    By Tangent in forum 1983 - 1991 (E30)
    Last Post: 05-21-2006, 02:40 AM
