RM European Auto Parts
Page 4 of 4 FirstFirst 1234
Results 76 to 79 of 79
Thread: 2000 bmw 528i misbehaving again :(
  1. #76
    Mar 2017
    Missouri
    2000 bmw 528i, 2004 bmw
    Officially, these are replaced every time they are removed. You can reuse them; they are not torque-to-yeild bolt, but you must clean the old loctite off with a wire wheel, and apply new (blue) loctite, then torque these the the correct spec.
    Be aware that if those bolts were loose enough to allow the flexplate to wobble, the flexplate is highly suspect now. I'd have to recommend replacing the bolts at this point, too, because they weren't tight, and may have undergone stress in an improper direction.
    Okay I will replace the bolts the flywheel still looks straight but I'll consider replacing it to. I didn't use loctite on them last time I put it together which is I guess where I went wrong. Theirs no signs of scraping on the flexplate only on the heads of the bolts so the flex plate should be fine. Do you know where I would find new bolts?
  2. #77
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Sure, but if you'll allow me, I try to subscribe to the theory about teaching a man to fish, rather than handing him a couple of sardines......
    Go to realoem.com
    Enter the last seven digits of your car's VIN at the top box, where it says "serial number"
    When your car comes up, select "Browse Parts"
    Then you go to "engine".....yeah, I know the flywheel doesn't seem like an engine part, but trust me.....
    Then select "Automatic; Flywheel"
    http://www.realoem.com/bmw/enUS/show...diagId=11_7484
    Ah....there they are: part number 5. See the 11 digit part number?:
    11227805885
    Now....copy that part number, and let's go to one of our excellent suppliers,
    https://www.fcpeuro.com/
    Hit "Search", paste the part number, and VOILA:
    https://www.fcpeuro.com/products?utf...ds=11227805885
    Ah, there they are, $4. each. You need, um, 8 of them, as I recall. The new ones come with their own loctite.
    Chris Powell
    BMWCCA 274412
  3. #78
    Mar 2017
    Missouri
    I understand that for sure, I wish I could find a manual transmission donor car while everything is apart. But no one has one for sale right now with out killing a perfectly good BMW and that's a crime.
    Thanks Chris you have been a huge help through all of this and I greatly appreciate you!
  4. #79
    Mar 2017
    Missouri
    To anyone who is reading through this for a cracked flex plate or broken flexplate bolts. Do yourself a favor and replace your rear main seal before you put it back together. My loose bolts knocked out my rear main seal and i had no idea until i put it back together and drove it for a week.
  1. 2000 BMW 528i with 90k for $10000?
    By ucberkeley in forum 1996 - 2003 (E39)
    Last Post: 10-10-2006, 05:43 PM
  2. 2000 BMW 528i - 5-speed manual
    By chazmo in forum BMW Cars For Sale / Wanted
    Last Post: 05-28-2005, 12:17 PM
  3. 2000 BMW 528i for sale...
    By INSPIRED M3 in forum BMW Cars For Sale / Wanted
    Last Post: 03-04-2004, 03:01 AM
  4. To Buy or not to buy a 2000 BMW 528i, opinions are appreciated
    By 5series4life in forum 1996 - 2003 (E39)
    Last Post: 08-28-2003, 11:55 AM
  5. FS: 2000 BMW 528i E39 steptronic
    By GriMpY in forum BMW Cars For Sale / Wanted
    Last Post: 07-10-2003, 06:19 PM
