RM European Auto Parts
Page 3 of 4 FirstFirst 1234 LastLast
Results 51 to 75 of 79
Thread: 2000 bmw 528i misbehaving again :(
  1. #51
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Again, note that I said "If you're sure that the tensioner is noisy, return it." Absolutely, Autozone selld crap parts....however, IF the noise is identical, after swapping those parts, there's a VERY strong possibility that you haven't yet identified the problem.
    You've spent SO much money, and SO much time, chasing this issue, that I really have to advise you have a BMW pro look at the car. It's possible that his experience might identify the sound instantly, or after a few minutes with a stethoscope. Please know that when I listen to a noise which I can't quite swear to, I call another tech over to listen, too. Four ears are better than two.
    Chris Powell
    BMWCCA 274412
  2. #52
    Mar 2017
    Missouri
    2000 bmw 528i, 2004 bmw
    I will try the other tensioner first. But yes the sound was still identical. Im trying not to spend alot of money at a dealer but i may have to ill try the other tensioner first and see what happens.
  3. #53
    Dec 2013
    Chicagoland area
    EXOTICS
    So true,
    sometimes in our attempt to DIY, and save some money in the process,
    a hard to pinpoint issue gets the best of all of us, due to a pro not actually being on site.
    Sometimes, maybe rarely, a professional actually standing next to the vehicle,
    can easily diagnose the problem, which can be difficult to achieve via internet.
  4. #54
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    I can recommend a superb shop - several actually in the KC area.
  5. #55
    Mar 2017
    Missouri
    Quote Originally Posted by shadowpuck View Post
    I'm in the stl area. It would be hard to get my bimmer across the state. Thank you though
  6. #56
    Mar 2017
    Missouri
    Welp I changed out the tensioner with the one from fpceuro and the sound muffled a little but didn't go away. And the sound is now harder to pinpoint I guess it was just resonating threw that worn tensioner. I will put my car completely together and drive it 32miles to the closes dealer and hope it makes it and they can help me.
  7. #57
    Mar 2017
    Missouri
    Took it to the dealer and it was diagnosed as the bolts to the flywheel need replaced.
  8. #58
    Dec 2013
    Chicagoland area
    EXOTICS
    This is one strange outcome for sure!
  9. #59
    Feb 2018
    caribbean
    09 x3
    Quote Originally Posted by MIKYZZ4 View Post
    probably means a cracked flexplate which will make terrible noises.
  10. #60
    Dec 2013
    Chicagoland area
    EXOTICS
    Noob44, I know it hasn't been mentioned,
    but did you have transmission/clutch work done recently?
  11. #61
    Mar 2017
    Missouri
    I definitely agree not what I expected.
    And the car is an automatic. But other than me bolting up the new block to it 4xxx miles ago no work has been done to it. But I may have miss torqued one of the bolts; it is possible I spent a lot of late nights working on it.
    Quote Originally Posted by stvsxm View Post
    I will check out the state of the flexplate while I'm in there and make sure it'd just a bolt and no cracks breaks or fractures.
    Multi-Quote This Message
  12. #62
    Dec 2013
    Chicagoland area
    EXOTICS
    Well, I am glad the mystery noise seems to be solved for you,
    hope all goes well, and it ends up to be an easy fix.
  13. #63
    Jun 2002
    E39M5, E500 4WD
    No....the flexplate IS the flywheel, on an automatic transmission. If the problem is indeed with your flexplate / flywheel, Steve's absolutely right, it's likely cracked. Now, it IS just possible that the bolts which hold the torque convertor to the flexplate are loose, and one has backed out, and is hitting something. This would be a REALLY good thing, IF you fix it immediately. This is the only possibility inside the bellhousing which does not involve removing the transmission.
    Still, the cracked flexplate is the most likely fault, if the noise is inside the bellhousing.
    Chris Powell
    BMWCCA 274412
  14. #64
    Mar 2017
    Missouri
    Sorry when it comes to transmission I know a lot less I didn't know if their was a difference between the fly wheel and flex plate. I may remove the transmission just to be sure that everything is okay and it's just bolts like autohaus bmw said. I'll post my update when I fix it. Thank you you guys for all your help and bearing with me on this giant headache.
  15. #65
    Jun 2002
    E39M5, E500 4WD
    I wouldn't remove a transmission unless I had to..... and besides....to remove it, you're going to have to undo the torque convertor bolts anyway. Why not just rotate the engine one revolution by hand, while checking those bolts (usually 3, maybe 4), with a 17mm socket? If they're all tight, then on the second revolution of the engine, just go ahead and remove them. But if you find one loose, and the head of the bolt is scraped up....you've saved yourself a ton of work.....replace those bolts if that's the case.
    Chris Powell
    BMWCCA 274412
  16. #66
    Mar 2017
    Missouri
    Okay If I remember right it's only 3 bolts. And do I access that from under the car or do I have to pull the intake. I don't remember where you gain access through. Also do you know the proper torque spec and is it acceptable to use lock tight so I don't have this issue again?
  17. #67
    Jun 2002
    E39M5, E500 4WD
    This is done from under the car. The access port should be under the exhaust manifolds, but it MIGHT be at the very bottom of the bellhousing. Generally, there's a rubber cover to be pulled off.
    Yes, you can use blue loctite If the bolts were actually tightened, they likely didn't come loose, and the flexplate is likely cracked. But maybe you forgot to turn the crank an extra ~90 degrees, and there were 4....or maybe one of the three just didn't get tightened.
    Torque, I dunno, probably 30 or 40 Nm. No room for a torque wrench here anyway. Assuming you're using a standard length 3/8 drive ratchet, pull hard. Maybe someone else will look up the torque for you, I'm late for work, sorry.
    Chris Powell
    BMWCCA 274412
  18. #68
    NW suburban Chicago
    hiss by my window
    I have the appropriate flexplate/flywheel serving paper weight duty. Yours for the cost of shipping should you need it. PM if so.
  19. #69
    Mar 2017
    Missouri
    Okay thank you, you've been a huge help I'll just tighten them the best that I can.
    Quote Originally Posted by ross1 View Post
    Okay thank you I will let you know. Imma try to get to the job in the next day or three. .
  20. #70
    Jun 2002
    E39M5, E500 4WD
    If they are not loose, do not tighten them. If the bolt heads are not damaged, loose torque convertor bolts are NOT your problem....
    If indeed the noise is in the bellhousing, I need for you to understand that the cracked flexplate is the most likely cause....I am just playing "devil's advocate", and trying to prevent you from removing the trans!
    Chris Powell
    BMWCCA 274412
  21. #71
    Mar 2017
    Missouri
    I understand that and either way bolts or the flywheel I'll replace it. I'm to far in to walk away.
  22. #72
    Jun 2002
    E39M5, E500 4WD
    I have seen that, by your previous posts. We're all with you, you're being very scrupulous.
    Chris Powell
    BMWCCA 274412
  23. #73
    Mar 2017
    Missouri
    Well all the bolts are tight so I guess I'm stuck dropping the transmission to examine the flex plate.
  24. #74
    Mar 2017
    Missouri
    After dropping the transmission the flex plate appears to be fine the bolts that go to the crankshaft came loose. Not the one that go to the torque converter.
  25. #75
    Jun 2002
    E39M5, E500 4WD
    Officially, these are replaced every time they are removed. You can reuse them; they are not torque-to-yeild bolt, but you must clean the old loctite off with a wire wheel, and apply new (blue) loctite, then torque these the the correct spec.
    Be aware that if those bolts were loose enough to allow the flexplate to wobble, the flexplate is highly suspect now. I'd have to recommend replacing the bolts at this point, too, because they weren't tight, and may have undergone stress in an improper direction.
    Chris Powell
    BMWCCA 274412
  1. 2000 BMW 528i with 90k for $10000?
    By ucberkeley in forum 1996 - 2003 (E39)
    Last Post: 10-10-2006, 05:43 PM
  2. 2000 BMW 528i - 5-speed manual
    By chazmo in forum BMW Cars For Sale / Wanted
    Last Post: 05-28-2005, 12:17 PM
  3. 2000 BMW 528i for sale...
    By INSPIRED M3 in forum BMW Cars For Sale / Wanted
    Last Post: 03-04-2004, 03:01 AM
  4. To Buy or not to buy a 2000 BMW 528i, opinions are appreciated
    By 5series4life in forum 1996 - 2003 (E39)
    Last Post: 08-28-2003, 11:55 AM
  5. FS: 2000 BMW 528i E39 steptronic
    By GriMpY in forum BMW Cars For Sale / Wanted
    Last Post: 07-10-2003, 06:19 PM
