RM European Auto Parts
Page 2 of 4 FirstFirst 1234 LastLast
Results 26 to 50 of 79
Thread: 2000 bmw 528i misbehaving again :(
  1. #26
    Mar 2017
    Missouri
    2000 bmw 528i, 2004 bmw
    https://youtu.be/Wlx3af6RQ2M
    This is the play I have.
  2. #27
    Mar 2017
    Missouri
    Tomorrow I will put it back together with the new oil pump chain and see what happens.
  3. #28
    Feb 2015
    London, United Kingdom
    E36 328is, E87 116i
    Make sure you use some good loctite and tighten the oil pump nut up good as it's a "reverse thread" and is notorious for becoming undone
    C217 S63 AMG S Cabriolet ( Daily )
    E87 116i with mild cams, headers, cold air intake making 136 bhp Lol (My Learning Track Car)
    E36 328i Sport ( Project in making and future race/track car )
  4. #29
    Mar 2017
    Missouri
    I definitely I haven't put all this time and money into this build to watch it die in a month; thanks for the reminder though
  5. #30
    Mar 2017
    Missouri
    Got the oil pump chain changed out and put everything back together and the rattle is still their... I listened around again and it sounded like maybe the power steering pump so I changed that out and started it up and the noise still continues to be their. I don't know what to do at this point im extremely stumped and frustrated at this point. Please someone help.
  6. #31
    Dec 2013
    Chicagoland area
    EXOTICS
    The noise is very noticeable at idle only,
    as it basically disappears with throttle applied.
  7. #32
    Mar 2017
    Missouri
    Quote Originally Posted by MIKYZZ4 View Post
    That is correct. Over 1500 rpms the sound goes away
  8. #33
    Dec 2013
    Chicagoland area
    EXOTICS
    Remove and inspect #15-19 for damage.
  9. #34
    Mar 2017
    Missouri
    I have already tried the secondary are pump. Also mine bolts straight to the head so I only have 15-16.
  10. #35
    Mar 2017
    Missouri
    I have left the car running for a bit while it makes the rattle and I have learned that it gets worse when I turn the wheel and it effects the rpms if the wheel is turned completely right or left. It has a brand new power steering pump and ive done my best to flush the power steering fluid (atf for my car) The atf cycles through and is foamy When it re enters the resivor. I don't want to jump straight to the rack and pinion yet. Is their anything else to try?
  11. #36
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    If the noise didn't go away completely when you ran the engine without the belt, it can't be the power steering. Regarding the steering, though: (1) it generally makes groaning noises, when it's having problems, not generally rattling. (2) best way to bleed the air is with engine off, front end off the ground, turn wheels from lock to lock about eight times. (3) If your rattle gets worse when you turn the steering, I'd suggest that your tensioner assembly may be bad, and/or perhaps the idler pulley. Get a mechanic's stethoscope and listen to the tensioner and the idler pulley bolt.
    Chris Powell
    BMWCCA 274412
  12. #37
    Mar 2017
    Missouri
    Okay I will give it a try and get back with my results. If its the tensioners/ idle pulley wouldn't the sound have also gone away without the belt?
  13. #38
    Jun 2002
    E39M5, E500 4WD
    Yes. However, you said the noise almost completely went away with the belt off; so start by fixing what you know is broken. The belt drive components must have something to do with it.....
    Chris Powell
    BMWCCA 274412
  14. #39
    Mar 2017
    Missouri
    I think you may be right I put the stethoscope on the idle pulley it sounded fine I put it on the tensioner pulley and it made my ear ring it was so loud. I'll buy a new one and hopefully this solves my issue.
  15. #40
    Dec 2013
    Chicagoland area
    EXOTICS
    Replace all tensioners and pulleys,
    seems like we're going in circles here !
    That's what I get for assuming all this was taken care of earlier.
  16. #41
    Mar 2017
    Missouri
    Replaced all tensioners, idler pulleys and belt and I am still getting a rattle in the same now brand new pulley. Behind the mount of this pulley is the oil filter housing could it be the anti-drainback valve causing my issue?
  17. #42
    Jun 2002
    E39M5, E500 4WD
    Put your stethoscope on the alternator. The idler pulley bolt is also the alternator mounting bolt.
    Chris Powell
    BMWCCA 274412
  18. #43
    Mar 2017
    Missouri
    The alternator is quiet when I say pulley I'm referring to the one on the tensioner below. The idler Pulley. Sorry I should have been more specific. The one that you move to undo the belt is the one making all kinds of noise and it's brand new now.
  19. #44
    Jun 2002
    E39M5, E500 4WD
    That is called the tensioner pulley, not the idler pulley. If you were able to buy JUST the pulley, not the tensioner assembly, then you must have a hydraulic tensioner, rather than the mechanical, clockspring type. Maybe the hydraulic tensioner is faulty, or the mountings are broken and loose.
    Chris Powell
    BMWCCA 274412
  20. #45
    Mar 2017
    Missouri
    I replaced the hydraulic tensioner as well with the pulleys. But couldn't find where to buy the piece that connects the two.
  21. #46
    Dec 2013
    Chicagoland area
    EXOTICS
    Was this what you installed?
    https://www.fcpeuro.com/products/bmw...1287838797-1-2
    Helpful video is included.
  22. #47
    Mar 2017
    Missouri
    https://m.autozone.com/external-engi...27_0?location=
    https://m.autozone.com/external-engi...86_0?location=
    https://m.autozone.com/external-engi...21_0?location=
    This is what I installed.
    The second link is where the sound is coming from.
    I couldn't find the part to connect link one and two without ordering it offline.
  23. #48
    Jun 2002
    E39M5, E500 4WD
    The second link is a tensioner pulley, not an idler pulley. That's one of the troubles with Autozone....they don't even know what the hell they're selling. The second problem is that they sell crap. If you're sure that pulley is still noisy, return it, it's bad. Which wouldn't surprise me a bit, considering where it came from.
    Don't buy BMW parts at Autozone, O'Reilly, Napa, Rock Auto, or similar generic garbage stores. But only from places that SPECIALIZE in BMWs, like FCP Euro, RM European, Pelican Parts, getbmwparts.com, etc.....
    Chris Powell
    BMWCCA 274412
  24. #49
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    and, i'd point out - if the poster is located near KC - the local BMW club chapter there has an amazing parts purchase program with Baron BMW. Members get BMW parts at a very competitive price. all you have to do is go in to the parts department and show your membership card.
    www.bmwcca.org/join
  25. #50
    Mar 2017
    Missouri
    Okay I will try a new tensioner and see what happens I don't normally buy stuff for my bimmer at AutoZone because I know it doesn't normally work but I figured maybe the sound would go a away to let me know if that was the issue.
    I will look into it shadowpuck thanks
  1. 2000 BMW 528i with 90k for $10000?
    By ucberkeley in forum 1996 - 2003 (E39)
    Last Post: 10-10-2006, 05:43 PM
  2. 2000 BMW 528i - 5-speed manual
    By chazmo in forum BMW Cars For Sale / Wanted
    Last Post: 05-28-2005, 12:17 PM
  3. 2000 BMW 528i for sale...
    By INSPIRED M3 in forum BMW Cars For Sale / Wanted
    Last Post: 03-04-2004, 03:01 AM
  4. To Buy or not to buy a 2000 BMW 528i, opinions are appreciated
    By 5series4life in forum 1996 - 2003 (E39)
    Last Post: 08-28-2003, 11:55 AM
  5. FS: 2000 BMW 528i E39 steptronic
    By GriMpY in forum BMW Cars For Sale / Wanted
    Last Post: 07-10-2003, 06:19 PM
