RM European Auto Parts
Page 1 of 4 1234 LastLast
Results 1 to 25 of 79
Thread: 2000 bmw 528i misbehaving again :(
    Mar 2017
    Missouri
    2000 bmw 528i, 2004 bmw
    When I start it up it rattles and grinds really loud. sounds like its internal but when I touch the gas it quiets down. I tried the starter and had no luck and i pulled the belt and the sound almost went away. Should i start with the water pump? The water pump is basically new. Ill try to get a video up of the sound. No cel either.
    186xxx miles
    Engine 4xxx
    Complete ac delete.
    Mar 2017
    Missouri
    Jul 2004
    Houston, TX
    36 Cylinders
    Well get a look under the car. Your exhaust is falling apart likely.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Mar 2017
    Missouri
    I know i have a catalytic converter i need to replace you think that could cause that sound?
    Mar 2017
    Missouri
    Okay so i got my catalytic converters replaced. New and oem and I am still getting the same sound. I used a long screw driver and listened around and the sound seems to be coming from the timing chain/vanos area (middle to top half, not lower). Where would be the best place to start? I rebuilt the vanos with the rest of the engine 4xxx miles ago along with new chains and guides but they where not bmw brand guides and tensioners. Please help I miss driving my car.
    Mar 2017
    Missouri
    The car had driven home just fine from work no odd sounds and then this sound started the next morning when I tried to start it up. I dont know if that helps at all.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Sounds like the timing chain and guides need some work.
    Charleston, SC
    '15 I01Rex , '11F25
    Try opening up the oil fill cap, I think you might have a bad PCV.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I’d put it on a lift or jackstands and run it in gear while you look and listen.
    Looks like you have put a lot of money into this car - rebuilding the engine and replacing the converters. Are you doing this yourself or paying a shop?
    Mar 2017
    Missouri
    I have done all the work myself I bought a new block and head and rebuilt the engine after a failed head gasket had destroyed the engine from the previous owner not stopping when the car over heated and i put everything back together based off of manufacture specs. And thank you all for your responses I will check these shortly and post my findings.
    Mar 2017
    Missouri
    Quote Originally Posted by ptarditi View Post
    The pcv also only has 4xxx miles on it but I can check.
    Dec 2013
    Chicagoland area
    EXOTICS
    It sounds like it's timing related, along with exhaust/converter.
    Dec 2013
    Chicagoland area
    EXOTICS
    Or, it could just be a loose heat shield, or metallic cover in the engine compartment.
    Mar 2017
    Missouri
    Its almost gotta be timing related at this point I already replaced the catalytic converters and nothing changed except a smoother idle. Im going to pull the front clip and timing chain cover when I get the chance and see what it looks like in there
    Dec 2013
    Chicagoland area
    EXOTICS
    Since the source of the symptoms is a mystery,
    I suggest a diagnostic scan, as a code may reveal a clue.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    A couple of things:
    You said that you drove it home after work, and there were no odd noises, but this noise started the next morning.
    Try this: unplug the secondary air pump, and then start the engine. Still make noise?
    Next, you said that the noise "ALMOST went away when you removed the belt". Maybe you have two noises, and one of them is a bad idler or tensioner pulley that's about to explode? Have you listened with a mechanic's stethoscope to all your pulleys?
    Chris Powell
    BMWCCA 274412
    Mar 2017
    Missouri
    A couple of things:
    When you say unplug the secondary air pump you mean the black part down it the passenger front fender correct? or do you mean remove the vacuum hose from the little pump off of the head? Sorry not trying to sound stupid just trying to properly diagnose the issue.
    And no I haven't listened to the pulleys but I can give it a shot. I just made the assumption that removing the belt relieved some tension off the engine/issue reducing the sound.
    Quote Originally Posted by MIKYZZ4 View Post
    The only codes I have are from the catalytic converter I just replaced on bank 1. And I haven't been able to drive the car for the code to clear.
    Jun 2002
    E39M5, E500 4WD
    Unplug the electrical plug, to see what effect it has on the noise. The secondary air pump runs for 30-90 seconds after a cold start, and when it's failing, it's incredibly noisy.
    Chris Powell
    BMWCCA 274412
    Mar 2017
    Missouri
    Okay I will give that a try and see what happens the sound is present for longer than 90 seconds though but ill still try
    Mar 2017
    Missouri
    No luck with the secondary air pump so I'm going to start tearing into the engine to get to the timing today. I'll let you guys know what I found.
    May 2017
    Owings, Md
    1998 328i
    This may be a long shot but it is a simple thing to check and rule out. Check the crankshaft damper bolt ("Jesus Bolt") to see if it has backed off. This is something that would sound different with the belt removed, (although I would have guessed it would be louder without the belt)
    Mar 2017
    Missouri
    Well my timing all still looked perfect and the Jesus bolt was definitely on. Their is some play in the lower chain that goes to the oil pump so I guess the oil pan will be the next thing to come off. See what the state of the oil pump and rod bearings are. The rod bearings should be fine since they are new but I guess I will find out soon.
    Mar 2017
    Missouri
    All my rod bearings look great still. And when I turn the engine by hand their no noise it's just quiet. So I guess I'm going to rebuild the oil pump and replace the lower chain. I haven't come across anything that just screams broken though. The chain has about 1/2in of play in it. Could that cause that much noise? I'm refering to the chain that goes to the oil pump.
    May 2017
    Owings, Md
    1998 328i
    I may have missed it but did you remove the timing cover? Did you replace the lower timing chain guides when you replaced the block? The oil pump chain should have a little slack, how are you measuring the 1/2"?, that doesn't sound excessive enough to cause your noise.
    Mar 2017
    Missouri
    Quote Originally Posted by gdavid View Post
    Yes I took the timing chain cover and oil pan off. Yes the guides where all replaced with the block. And it's just more of a guestament of how much play is there than a proper measurement. And I don't see that much play causing that much noise either but I can't find anything else that even looks slightly off.
  1. 2000 BMW 528i with 90k for $10000?
    By ucberkeley in forum 1996 - 2003 (E39)
    Last Post: 10-10-2006, 05:43 PM
  2. 2000 BMW 528i - 5-speed manual
    By chazmo in forum BMW Cars For Sale / Wanted
    Last Post: 05-28-2005, 12:17 PM
  3. 2000 BMW 528i for sale...
    By INSPIRED M3 in forum BMW Cars For Sale / Wanted
    Last Post: 03-04-2004, 03:01 AM
  4. To Buy or not to buy a 2000 BMW 528i, opinions are appreciated
    By 5series4life in forum 1996 - 2003 (E39)
    Last Post: 08-28-2003, 11:55 AM
  5. FS: 2000 BMW 528i E39 steptronic
    By GriMpY in forum BMW Cars For Sale / Wanted
    Last Post: 07-10-2003, 06:19 PM
