I have a problem with the halos on the passenger side of my e90, when the engine is off everything works fine but when I turn the engine on, the halos of the passenger side go out. I had to wire the halos in separately and I know I wired them in correctly because the drivers side works fine. I tried to correct the issue by grounding the halos to the chassis ground instead of at the headlight harness ground, but I still got the same result. Maybe its because my battery isn't charged all the way? any ideas?
