RM European Auto Parts
Results 1 to 5 of 5
Thread: Checking to see if blower fan out
    Mar 2016
    neenah,wi
    2004 352i 2002 325xi
    Good day. E-46 xi. The heater blower fan not working. I have checked fuses, all good. Checked power at blower fan, with test light, power here. Would it safe to assume blower fan out? Just checking in case I missed something.
    Mar 2016
    neenah,wi
    Another weird thing, looking things over is the motor housing suppose to be energized? IMG_0661.jpg Maybe hard to see, but end of test light is touching motor housing. The other end hooked to ground. Should motor housing be energized?
    Mar 2016
    neenah,wi
    I pulled fan motor out hot wired it works. So would next step be blower resistor pack? Any one out there?
    I pulled fan motor out hot wired it works. So would next step be blower resistor pack? Any one out there? Any way to test pack?
    Mar 2016
    neenah,wi
    OK. I put motor back. While digging into resistor, fan kicked in loose wire I guess!
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    On any E46, if the blower doesn't work, and the fuse is good, I just go ahead and replace the final stage resistor. Further diag is a waste of the customer's money, because the FSR is an absurdly common failure part. In ? ~200 FSR replacements, I might have been wrong once.....maybe even twice?
    My 2 cents.
    Chris Powell
    BMWCCA 274412
  1. How would I check to see if the head is damaged?
    By newton22 in forum 1996 - 2003 (E39)
    Last Post: 05-28-2009, 09:10 PM
  2. Replies: 11
    Last Post: 09-29-2007, 05:16 PM
  3. Replies: 6
    Last Post: 07-05-2007, 04:52 PM
  4. how to check to see if wheel bearing is bad???
    By mkalle1 in forum 1991 - 1999 (E36)
    Last Post: 04-18-2003, 12:01 PM
