Results 1 to 13 of 13
Thread: Snapped Wheel Bolt Help
    Nov 2017
    San Diego
    1991 318is
    Hi guys, so as the title says one of my lug/wheel bolt snapped in the wheel bearing hub. I went to autozone and got a bolt extractor set and when it started threading, that bolt snapped . So anyone have any ideas to get it out... Also is it safe to drive the car right now with 3 of 4 bolts in as this is my only daily, and I travel about 100 miles a day... Please let me know!
    Dec 2014
    miami fl
    1995 525i
    take it to a shop or replace the hub while you're at it, this happened to me a while ago, the nut that stayed attached broke the caliper, it took a while to break tho and it could've been worse
    Nov 2017
    San Diego
    1991 318is
    Yea im on a little budget, I got a grinder and started smoothing it out so nothing is rubbing on it, but is it ok driving my normal distance though with only 3 instead of 4?
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    I've driven a lot of 5 lug wheels with a lug broken so only had 4 bolts holding. However 1 out of 4 broken is different in that you loose 25% holding vs 20%, also the gripping pattern is significantly more uneven. I certainly would not drive fast and avoid any undue stress on the wheel such as rapid starts and stops and rough roads.
    Your only option would seem to be drill the bolt out. You have to be really picky in centering your drill bit. Start small and progressive use larger size bits. After most of the bolt is drilled out, may be able to use an easy out to remove the rest without damaging the thread. You must be careful not to damage the thread. Another option is to weld a nut to the broken bolt. All the heat seems to free up the bolt. Any time when removing a stubborn bolt, heat it with your propane torch.
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    There's no way he'll be able to drill it out. He already broke the extractor off.
    "Howdy, Folks!"
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    I've drilled ez outs before but I had some really, really good bits - long time ago so can't tell you much.
    Jan 2018
    Healdsburg, CA
    e30, e36, e46, f30
    14vlopez,
    Next time you break a bolt of any kind, take a moment to grab your phone and take a picture. Then post it on a hosting site like http://postimages.org/.
    The problem with using a grinder and trying a simple ez-out is that you've removed material from the bolt you want to extract. You don't want to do that. You never know when you could have cut a cross hatch in it or shaped it to a wrenchable condition.
    You need to swap that hub (do the other if you can) ASAP and avoid driving it for long with your 3 lugs holding. Give yourself extra room, keep your top speed down and avoid hard braking while turning on that wheel. Take a torque wrench and 17 or whatever your lugs are and check it before you drive it every time. Make sure those bolts are torqued. Obviously if they are backing off, you want to avoid driving as much as possible. 100 miles per day is probably enough to work these free in stop and go traffic. Just be safe, leave distance, check the bolts and keep the remaining ones tight.
    You can pull good enough hubs and bearings from the junkyard. Just learn how to test them and check a bunch if you have the option. I am still totally willing to help you, but assuming you've ground off all the protruding material, you just need to replace the hub. Those fronts are sold pressed into new hubs and are simple to do at home with hand tools.
    Erik
    Albuquerque, NM
    way too many
    If you can grind the broken Easy-out flush, try using a carbide tipped concrete drill, 3/8" might work if you can hit it close to center. The heat and vibration from the drill might help loosen the bolt. If you rotate the flange so there's nothing in the way behind it, the bolt may loosen and drive all the way thru. Use PB Blaster, or even better, a 50/50 mix of ATF and acetone.
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    Jul 2013
    CT
    1989 325i 4 Door 5sp
    If you have a dremel like tool, carbide tungsted die burr cutters will remove the ez (hard) out.
    Athol, MA
    87 M6, 90 325iC, 89 iX
    Is there any part of the stud sticking out past the wheel? If so, I have escaped tragedy by welding a nut onto what is left of the stud and using that with a socket to extract it. The heat from welding also seems to have the added benefit of loosening things up if they are a bit rusted. If you don't have a welder maybe a local shop could do this for you.
    "Life is too Short to drive boring cars"
    1986 325E
    1989 325iX (Long term 5-speed/refresh project)
    1993 MB 300E
    1995 MB E320
    2000 Audi TT (Winter AWD snow beast)
    2007 Porsche Cayman S (Summer car)
    2009 VW Touareg
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    Quote Originally Posted by 1SGDHORN View Post
    I think he grounded it off - if so, I would just find a new hub.. (maybe junk yard or eBay)
    Pull the and replace the hub and wheel bearing.. as ejengstrom suggests.
    Nov 2017
    San Diego
    1991 318is
    Sorry for late reply guys but I was able to find a guy parting out his e30, and just bought the entire spindle from him for $170, everything else after that just went to shit. I had to buy a new control arm as the old one the bolt and nut were seized, outer tie rod nut and bolt seized, sway bar U bracket seized, so I had to go to the BMW dealership to get the missing nuts and bolts... But everything is all put together so Murphy's law definitely hit me this time... All from one broken wheel stud lol
    Nov 2009
    Des Moines, IA
    Quote Originally Posted by 14vlopez View Post
    If things are that bad - it sounds like you need to replace the other side suspension components as well (and most likely rear too.)
    New suspension components can really transform the handling of an old car.
    I understand the budget constraint - so keep an eye out on Craigslist for other deals - make plans now before the other ones give out..
  1. cannot loosen wheel bolts.......help!
    By cnowak1 in forum 1983 - 1991 (E30)
    Last Post: 07-01-2009, 05:49 PM
  2. Help! Snapped a bolt
    By chandlerseattle in forum 1992 - 1999 M3 (E36)
    Last Post: 04-14-2008, 03:29 PM
  3. Need help with the diff rebuild after it snapped the bolts
    By Sarwat in forum 1991 - 1999 (E36)
    Last Post: 01-07-2008, 05:50 PM
  4. HELP Wheel Bolt issue
    By krystian in forum 1991 - 1999 (E36)
    Last Post: 10-18-2006, 10:46 PM
  5. Need help! Wheel bolt issue!
    By M50E30 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 11-10-2002, 06:07 PM
