Results 1 to 12 of 12
Thread: Open diff vs lsd
    Dec 2014
    miami fl
    1995 525i
    Open diff vs lsd
    Hello people! My 1990 e30 that I bought came with a rear whining noise, definitely the differential...locally there's a guy selling two different diffs, a z3 open differential with 80k miles, and a lsd with 140k from an e30 each for 200, I don't really know which one would be the best choice, mine works but it gets loud, and its not the bearing because i can hear them too, my lsd has more that 350k miles, I think for the price is worth the try?...which one would you go for, I want to do normal driving no racing or drifting
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    What are the gear ratios? Likely would be the LSD from the e30 as long as it isn't the small case ones used in the 318i.
    "Howdy, Folks!"
    Sep 2016
    Belgrade
    Quote Originally Posted by fabianzam View Post
    Why do not you try it with oil? My diff also works fine but have whining noise. I put Motul 75w90 and and the noise down and do not worry too much.
    Dec 2014
    miami fl
    1995 525i
    Both have 3.73 ratio
    That's the first thing I tried when I bought he car :/
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Since you drive reasonable and live where the snow does not get too deep, I would go with the the 80,000 mile one.
    Dec 2014
    miami fl
    1995 525i
    Dec 2014
    miami fl
    1995 525i
    Finally someone helped me while I looked under the car
    I notice wheels both turn opposite ways so I have a open diff, can they wear out like that??
    Dec 2014
    miami fl
    1995 525i
    Up
    Regina, Sask, Canada
    82 320i 89 325i
    short answer
    grab them all...
    in reality get the lsd tho and rebuild or refresh it along with your original diff. its not that hard. i've done bmw and other ls diffs including gear changes and if i can swing it anyone can
    82 320i 89 325i
    yes. but likely it is an open diff. pop rear cover to confirm, i always do this when buying an ls diff now if it's off the car or i walk.
    edit: oops read that a bit wrong, actually don't pop the cover unless removing diff to work on lol
    if the rear wheels are off the ground you can get helper and try the ls test
    Dec 2014
    miami fl
    1995 525i
    Quote Originally Posted by 82eye View Post
    i meant to say i lifted the car and i checked, they spin different ways, so i currently have and open diff
    so update...i went to see them today, and i bought the z3 differential, it felt tight when i turned it, it felt right, i gave it a spin and they went the same way and i bought it right away. the guy didn't let it go for less than $250, but only because he thought it was an open diff, come up?
    any imput on the vid?
    82 320i 89 325i
    they will pretty much always spin the same off the car
    edit: you will have to swap output flanges. super easy. they just pop out and back in. there's a little spring clip as well.
  1. How to convert open diff to LSD?: internal parts...
    By nuvola rossa in forum 1991 - 1999 (E36)
    Last Post: 06-21-2011, 02:12 AM
  2. Converting an open diff. to LSD
    By ramzisleiman in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 01-03-2010, 06:37 AM
  3. Open diff vs LSD diff question
    By ngcreese in forum 1983 - 1991 (E30)
    Last Post: 10-16-2009, 04:10 AM
  4. 3.9:1 open diff to lsd
    By Varden in forum 1975 - 1983 (E21)
    Last Post: 06-14-2008, 09:19 PM
