Results 1 to 11 of 11
Thread: Metal piece found on transmission oil drain plug.
    Nov 2017
    Boise, ID
    '83 e21 320i
    Picked up my '83 320i with the 5 speed a few months back. I went to change the transmission and diff fluid today and found this metal shard on the drain plug of the tranny :O
    Looking through the Hayes manual it looks like it could be a number of different parts.... does anyone have any idea?
    Car drives and shifts fine, but when cold 1st and 2nd are very difficult to get in gear. Overall it is a bit notchy too. Putting in some MTL today based off my reading of other threads here.
    Sent from my SM-N920V using Tapatalk
    Nov 2017
    Boise, ID
    '83 e21 320i
    Found another larger piece in the drain pan....
    Jul 2010
    San Jose, California
    E21 320i, E30 325i
    Quote Originally Posted by creepshow View Post
    Drain pan? Of a 5 speed?
    Maybe a shift fork? http://www.realoem.com/bmw/enUS/show...diagId=23_0532
    '81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
    Nov 2017
    Boise, ID
    '83 e21 320i
    I just mean the plastic pan I let the transmission oil drain into. So that piece must have just flowed out while it was draining.
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    Did Randy go to bed early again?
    Mar 2013
    Santa Rosa, CA
    1981 320i silver
    It is a piece of the part that the shift fork pushes against when you go to change gears, it is cylindrical with a shoulder. That's what the shift fork contacts, the shoulder.
    A piece of slider #14 which is moved by the fork. 13 and 15 are synchronizers.
    Nov 2017
    Boise, ID
    '83 e21 320i
    Thank you amarino and okieflats for the quick identification. Could this cause any serious damage to continue driving it this way? I imagine it's been this way for a long time.
    My guess would be since the shift fork makes contact with approximately half the circumference of the slider, a missing piece of the slider contact surface wouldn't affect the overall contact between the fork and slider ring.
    Worth investigating more?
    Pioneer, CA
    73' tii 79 320i 73'2002
    I would use regular oil, not synthetic at this point. drain and check the magnet much more often (500 miles?) to see if you are getting more metal. Find a way to glue a bigger magnet around the drain plug and make sure you catch as much steel as possible from circulating and getting caught in the gears.
    Jul 2010
    E21 320i, E30 325i
    Quote Originally Posted by tlapham View Post
    Maybe try some tiny rare-earth magnets? https://www.homedepot.com/p/MASTER-M...45HD/202526363
    Bayview, WI
    1983 BMW 320i M20 Turbo
    I had a scare that I dropped a nut down the timing cover into the pan on my old m10. I ended up sticking a few flat ring magnets on the bottom and sides of the pan from the outside as a precaution. Years later when I took the m10 out to swap in an m20, I pulled the oil pan off and guess what was stuck to the pan where one of the magnets was? Yup, the nut I dropped. Safe and sound. lol
    1999 Z3 Coupe 2.8L
    CHECK OUT >>>
    RAGE DRIFT DESIGNS <<< FOR DECALS AND MORE!
    Nov 2017
    Boise, ID
    '83 e21 320i
    I'll go ahead and slap some magnets on the underside and change the oil in it more often and just hope I don't find any more pieces then.. sounds like the magnet method has been proven. Thanks guys.
  1. Snapped Oil Drain plug, is it okay to drive on?
    By bay707 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-21-2009, 11:29 AM
  2. collar on oil drain plug?
    By wasp in forum 1999 - 2006 (E46)
    Last Post: 09-28-2007, 11:00 AM
  3. Torque Spec for Oil Drain Plug?
    By kdahlstrand in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-30-2002, 03:49 PM
  4. Where is the engine oil drain plug in the E46 M3?
    By LEVOC///MPower in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 05-21-2002, 09:55 AM
  5. Stripped my oil drain plug. Please advise
    By The Tick in forum 1991 - 1999 (E36)
    Last Post: 09-05-2001, 05:47 AM
