Picked up my '83 320i with the 5 speed a few months back. I went to change the transmission and diff fluid today and found this metal shard on the drain plug of the tranny :O
Looking through the Hayes manual it looks like it could be a number of different parts.... does anyone have any idea?
Car drives and shifts fine, but when cold 1st and 2nd are very difficult to get in gear. Overall it is a bit notchy too. Putting in some MTL today based off my reading of other threads here.
Sent from my SM-N920V using Tapatalk
Found another larger piece in the drain pan....
Drain pan? Of a 5 speed?
Maybe a shift fork? http://www.realoem.com/bmw/enUS/show...diagId=23_0532
'81 E21 320i / '90 E30 325i / '̶9̶2̶ ̶E̶3̶4̶ ̶5̶2̶5̶i̶t (sold) / '15 Toyota XW30 / '̶̶8̶0̶ ̶E̶2̶1̶ ̶3̶2̶0̶i̶A̶ (sold)
I just mean the plastic pan I let the transmission oil drain into. So that piece must have just flowed out while it was draining.
Did Randy go to bed early again?
It is a piece of the part that the shift fork pushes against when you go to change gears, it is cylindrical with a shoulder. That's what the shift fork contacts, the shoulder.
A piece of slider #14 which is moved by the fork. 13 and 15 are synchronizers.
Thank you amarino and okieflats for the quick identification. Could this cause any serious damage to continue driving it this way? I imagine it's been this way for a long time.
My guess would be since the shift fork makes contact with approximately half the circumference of the slider, a missing piece of the slider contact surface wouldn't affect the overall contact between the fork and slider ring.
Worth investigating more?
I would use regular oil, not synthetic at this point. drain and check the magnet much more often (500 miles?) to see if you are getting more metal. Find a way to glue a bigger magnet around the drain plug and make sure you catch as much steel as possible from circulating and getting caught in the gears.
Maybe try some tiny rare-earth magnets? https://www.homedepot.com/p/MASTER-M...45HD/202526363
I had a scare that I dropped a nut down the timing cover into the pan on my old m10. I ended up sticking a few flat ring magnets on the bottom and sides of the pan from the outside as a precaution. Years later when I took the m10 out to swap in an m20, I pulled the oil pan off and guess what was stuck to the pan where one of the magnets was? Yup, the nut I dropped. Safe and sound. lol
I'll go ahead and slap some magnets on the underside and change the oil in it more often and just hope I don't find any more pieces then.. sounds like the magnet method has been proven. Thanks guys.
