Results 1 to 7 of 7
Thread: Help with DCAN cable drivers
    Jan 2018
    Dallas,TX
    98 540i sport
    Exclamation Help with DCAN cable drivers
    hello all i have a 98 bmw 540 that i did major surgery (engine and tranny swap ) this will be my new account you can see my thread under the name simon528i of the whole process and it will give you an idea , i had to make this acc because i lost my password to the other okay got that out the way the problem i am having is ive downloaded mikes easy tool kit online about 4-6 times by now and eerytime i do the drivers that are included fail to install everytime. i am running a laptop with winodws xp as i heard these softwares run better on the older computers, i have a newer laptop to my use but it is a chromebook i also have a desktop runnig windows 8 and is pretty capable but i really dont want to take my home pc to my shop... my question is are there certain drivers required? do i have to use the ones inclded with mikes easy? can i use any generic dcan driver so that my laptop will recognize my cable when plugged into my car and running inpa?? does anyone have a driver file i can try??? any help will be greatly appreciated
    Jul 2004
    Houston, TX
    36 Cylinders
    Is the cable white mainboard or green?
    These drivers here should be fine http://www.ftdichip.com/Drivers/VCP.htm
    But it depends if it's white or green.
    White mainboard ones tend to be bricked by the newest ftdi drivers, because they contain counterfeit FTDI chips.
    Windows version has nothing to do with it. XP is not needed. Win7-Win10 will work just fine.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Tampa, FL
    '06 BMW X3
    Are ALL white board cables bad?? I just bought a new one off of Amazon that's white. One with a switch to jumper pins 7/8. Out of the box it was broken and I had to re-solder the wires to the pins from the switch. Pretty crappy quality overall.
    Jul 2004
    Houston, TX
    36 Cylinders
    All *Chinese* white board ones? It's possible, yes.
    I was given a white board one by someone, and it works for a while, until the FTDI drivers erase the Hardware ID in the cable (VID to 0000), and then it becomes an unknown hardware item. There are ways to get it back to the correct VID and it works again, for a while.
    Green board of about 10 years old is still functioning just fine. I'm sure the green board has a counterfeit FTDI chip as well, but the circuitry or something must not allow the hardware ID change.
    -Abel
    Jan 2018
    Dallas,TX
    98 540i sport
    https://imgur.com/a/hy99F is this a “green board”
    Jan 2018
    Dallas,TX
    98 540i sport
    based on my dcan cable and my laptop which file should i download
    Jul 2004
    Houston, TX
    36 Cylinders
    Yes, that is a green board.
    For the XP laptop you need this most likely http://www.ftdichip.com/Drivers/CDM/CDM20824_Setup.exe
    -Abel
  1. Need help with INPA Cables
    By E39Fisch in forum Diagnostic Software
    Last Post: 10-04-2011, 01:24 AM
  2. Can't access to a '09 E87 with DCan cable... ?
    By Orphee in forum Diagnostic Software
    Last Post: 05-17-2011, 08:35 AM
  3. help with speakers.. (cable from door to cabin...)
    By CrysAk in forum 1996 - 2003 (E39)
    Last Post: 10-09-2010, 03:47 PM
  4. ASC fault / Help with adjusting cable please.
    By kaineb in forum 1991 - 1999 (E36)
    Last Post: 04-17-2009, 12:30 AM
  5. Please help with my locks- Driver dont wont unlock!!!!
    By Bimmer4699 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-16-2008, 05:00 AM
