I’ve been doing a lot of searching/reading because I need a set of 15” wheels for my i car. I really like the look of the mesh style but I keep reading negative stuff. Typical things like “I have a set of Beyern mesh on now (please no hate it’s only temporary)”
1987 325e, coupe, 5speed
1989 325i, sedan, 5speed
There's nothing wrong with Beyern. The wheels themselves are made by TSW, which isn't a notably high end wheel manufacturer, though you'd be hard pressed to ever break one during normal driving. Much emphasis is put on having either period correct wheels, or a variant of BBS', such as the RS line. That being said, many of those wheels are getting so expensive and rare these days that they cost more than your car. There are also a lot of "replica" wheel manufacturers out there (mostly sticking to replicating a BBS-style wheel, one of the more desirable styles), some of which are decent, daily-driver quality. Ironically, many people giving Beyern negative comment are running replica wheels, which are gratuitously affixed with a BBS center cap . If I were to give Beyern one bad rap, it's simply that they're mass-produced, so there isn't much uniqueness to their styling. You don't have to look far to find another E30 with Beyern Mesh wheels. As long as that doesn't bother you, there is nothing wrong with rocking a set.
1997 328i/4/5 - Cosmosschwarz Metallic on Dove Grey - Auto/Manual Swap - M3 Bilstein Sport/H&R Sports (95 M3 mounts) - Offset M3 LCAB - 20mm M3 rear sway bar - X-Brace - AA Tuning Strut Tower Bar - Rogue Engineering RSM - Dinan Cat-Back - 3.38 LSD - E46 330 front/328 rear brakes - SS Brake Lines - E36 fitment Style 42's (staggered) - M3 Front Bumper - M3 side moldings - M3 Rear Diffuser - DJ Auto Headlights (6k HIDS) - Frenched Fogs - OEM Clear Tails - E65 Rearview Mirror (Homelink controls + Autodim) - Alpine Type S Cabin Speakers (6x9 Retrofit) - 8" JVC woofer - Black Kidneys - Red Needles/Chrome Gauge Rings - OEM Alarm - Full Interior/Trunk LED Lighting - Mishimoto Full-Aluminum Radiator - More to Come!
Because most people don't like the way they look. Rarely is any choice in car modifications a logical decision, they're all emotional.
If you like the wheels, then you should proudly rock the wheels.
If your e30 runs bad, switch to Megasquirt first. Then try new spark plugs, cap and rotor, wires, oxygen sensor, crank shaft position sensor, coolant temp sensor, air flow meter, idle control valve, throttle position sensor, digital motor electronics unit, harmonic balancer, fuel injectors, engine harness...
Yes. Because they are hideous.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
People hate everything that isn't stock or 80s BBS.
Beyern Mesh seems to be the new Ronal LS.
87 Zinno Cabrio 98k Barn Find. Build thread http://www.r3vlimited.com/board/showthread.php?t=268987
87 Lachsilber ETA Time Capsule. bought w 125k from 87yo original owner
Cabrio deck lid & hinge struts (w sleeves) now for sale. See the link below for more info
New "made in Europe" seat shocks. PM for details
http://www.bimmerforums.com/forum/sh...ot-Seat-Shocks
