Results 1 to 25 of 30
Thread: Anyone with the Nerptech offset rtabs?
    Jan 2014
    San Antonio
    98 328is
    looking to see if anyone is currently running these on their car. wondering if they are any good and what their thoughts are. My rtabs are dead. i want to get a new set, and i want to be able to not have the toe issue when going to 0 camber.
    http://nerptech.bigcartel.com/produc...inserts-rtab-s
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    Dont have them, but want them. I am currently using the garagastic offset delrin ones and....gross.
    Aug 2008
    Lakeland Florida
    1999 328ic , 2002 325xi
    Those don't look like they have much articulation in twist. Probably not much better than poly or delrin bushings. Looks like they have less than a 1/8th inch misalignment in any direction.
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    https://store.garagistic.com/BMW-E36...g-arm-bushings
    These are the ones I have. They work but I did not have a good time ordering from that company.
    This is the one that seems to be the standard for spherical rtabs, but no toe offset
    http://www.bimmerworld.com/Suspensio...aring-Kit.html
    and the nerp ones
    Jan 2014
    San Antonio
    98 328is
    Yea, id def be getting the bimmerworlds or syncro design works. But the cost + no toe adjustment is a downside.
    Feb 2010
    Chapel Hill, NC
    1985 535i
    Quote Originally Posted by Novablue454 View Post
    This ^^^ one of mine cracked. I really need the nerptech ones.
    May 2009
    dover
    none
    whats the point of the offset, I'm pretty low running less than 2 degrees of camber. Would the normal spherical rtabs not allow enough adjustment?
    IG: dimitriantoniou
    Jan 2014
    San Antonio
    98 328is
    I want to run 0 camber in the rear. It messes with toe the closer you get. These will give you the adjustment/offset to have normal toe
    May 2009
    dover
    none
    So in all stock form, low car, zero camber, do you have too much toe in or toe out?
    Currently I'm close to zero camber and low and my car is toed in. My advice is to run a little bit of negative in the rear. Ive had luck with about -1 in terms of tire wear with my cars. Helps with side grip and the tire rolling over and chewing the edges up.
    IG: dimitriantoniou
    Aug 2008
    Lakeland Florida
    Or just don't run your car low?
    The bimmerworld spherical's in my opinion are the best option. The nerptech bearings aren't very well designed given the very limited misalignment capability. Delrin is generally pretty crap since it does not have the required flexibility that joint requires.
    The RTAB joint doesn't just rotate around the bolt but there is a side to side twist through its travel that needs to happen or you encounter major suspension bind and it hurts performance. I actually use factory RTAB bushings with the poly limiters with good results soo yeah.
    fairfax,va, usa
    2 E30s and a maxima
    Stock mount with poly limiter seems to be what most people use. I don't get it tho. Seems like it would be more likely to bind. I plan to go spherical eventually. But I have the poly limiters for now.
    May 2009
    dover
    none
    Quote Originally Posted by Piner View Post
    Half the fun in drifting is style, for me having a car that looks cool is just as important as it functioning well. I'm not a believer in delrin rtab, I'm thinking about Sycro design works, the sealed bearing seems great for a car that's not a trailer queen. Texas is dusty as hell lol. Any reason you'd choose BM over SDW?
    IG: dimitriantoniou
    Aug 2008
    Lakeland Florida
    Well the BW and the SDW RTABs are exactly same in function. The SDW part has a nicer appearance but since its going into a place you will never see. The BW part is $65 cheaper and uses the exact same bearing.
    I like the orange coating on the SDW RTABs but it isn't worth another $65 to me.
    and as for the lowness being a style thing, Style to me is just an opinion since most of the cars that people say are "Style" focused I find to be just recycled Early 2000's D1 copy cat cars that all follow the same general formula (Almost unusable low, Metal flake paint or wrap, huge wing at ridiculous AOA, Flashy JDM wheels, Huge chrome Japanese style graphics, dumb looking body kit) . I don't personally think imitating that look is the definition of style. I enjoy function focused styling because it has purpose.
    I liked those cars back when I was in high school (graduated '05) when that WAS the style at the time. Now they just seem silly and dated. I can't see my car from the outside while I am driving. Only thing I care about is if it is holding me back. I always want to push myself as far as I can and having a car that handles properly makes me happier than whatever I get out of having a car that looks cool but handles like crap especially since I know how much nicer a car that isn't too low feels.
    I always get setup questions from people and generally the advice that will help the most is to simply raise their car up but no one wants to hear that.
    BALTIMORE
    Would anyone be interested in an offset bushing that uses an OE BMW ball joint/bearing as well?
    The models pictured were made with arbitrary spitball numbers in my head, so they won't necessarily look the same as how they do now. I just wanted to draw up a quick model to help me illustrate what I've got in mind.
    If I get at least a few interested parties, I'll go take some real measurements and make a prototype. As far as pricing goes, I'm thinking $120 shipped will do the trick. That wouldn't include the ball joint/bearings though. From what I've seen on pelicanparts, you can get a pair for anywhere between $15 and $60, depending on brand.
    Popular engine swap weights & stock engine weights
    M42 + trans - 427lbs
    302 + t5 trans - 475lbs
    m20b27 + g260 - 497lbs
    m52b25 vanos + g250 - 544lbs
    351w + t5 trans - 572.5lbs
    LS,
    aluminum block + t56 - 609lbs
    LS, iron block + t56 - 719lbs, EST.
    http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
    Apr 2013
    Kelowna, Bc, canada
    1995 BMW M3 coupe
    They’re $75 Canadian through the dealership
    May 2009
    dover
    none
    ^ thems is fighten words..
    I can understand where you're coming from. I don't like the cars you described either, I honestly don't like most cars I see lol. I'll take some measurements of my rockers and you tell me if you think its functional (i have no idea what ideal height should be)
    Also I didn't know BW kit was sealed as well, thanks for the advice, easy way to save some money!
    IG: dimitriantoniou
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I have to run offsets, because my car is slightly tweaked from multiple hits and even though it measures straight on a frame rack, it was impossible to get 1/4" toe in on pass rear. Now its got 1/4" in on both rears with the offsets. IDK, its odd
    Feb 2010
    Chapel Hill, NC
    1985 535i
    This ^^^ my chassis is also tweaked from a few impacts. I have offset rtabs and cncd toe brackets and a thinner bolt head where the trailing arm connects through the bushing. Right now at zero camber I can still run about half a degree toe in.
    Sort of related question. For those of you running poly/delrin rtabs what are you setting your rear toe to? I'm about to drop it down to ~zero so when it compresses it doesn't go crazy toe in and destroy my tires.
    May 2009
    dover
    none
    Quote Originally Posted by Jrcanes55 View Post
    Probably has to do with spring rates/ride height. I cant imagine with changes much if you're on a decent coilover set up. Maybe through big bumps but not just on power drift. (pure speculation)
    IG: dimitriantoniou
    Jun 2015
    Denver, Colorado
    99 328i, a few more
    I'm on Fortune 8k / 7k coils at about stock ride height, 0* camber and 1/4" toe in per side. I am fighting for grip though, I would imagine with less power you would want a more neutral toe.
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by jalopi View Post
    Excuse me for being dense, but am I right that the purpose of this setup is that the factory style ball joints would be more durable than spherical bearings, while providing the required articulation?
    BALTIMORE
    Quote Originally Posted by tptrsn View Post
    Spot on sir. Or at least that's the idea anyway. They'd have the same basic functionality/benefits of the Bimmerworld RTABs, only they'd be offset for slammed/tweaked cars
    LS,
    DeWitt, Michigan
    Jan 2014
    San Antonio
    98 328is
    So, heres the real question then. i am not slammed by any means. i am lowered on Tein Basics. on 17x8+20 style 5s with 215/40 (maybe 45, i cant remember) i needed a slight roll on the fenders because of the drop. the wheel/fitment is on point in the rear.
    with that said, i know its hard to tell for sure, but since im not slammed, but just lowered, would i need the offset rtabs if i want to get to 0 camber in the rear with maybe 1/4" toe in on each side?
    BALTIMORE
    I was also lowered, not slammed, on GC coils and had no problem setting my toe at zero camber with standard RTABs. That being said, there are lots of variables at play, so your mileage may vary
    LS,
  1. Anyone with the engine software...
    By grmaster1 in forum 1999 - 2006 (E46)
    Last Post: 03-26-2004, 09:41 AM
  2. anyone with the BMP multiple throttle body intake?
    By il Paffuto Uno in forum 1991 - 1999 (E36)
    Last Post: 11-17-2003, 01:11 AM
  3. Pic Request: Anyone with the Colgan Front Bra on?
    By NoSoup4U in forum BMW Rides & Events
    Last Post: 03-28-2003, 12:20 PM
  4. Calling anyone with the BV Autosport SRS reset tool...
    By Aaron (ATL) in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-02-2002, 11:21 AM
  5. Anyone with the 6000K Philips HID?
    By bennyblanco in forum 1991 - 1999 (E36)
    Last Post: 12-13-2001, 06:01 AM
