Originally Posted by
Layne
I *think* the flange from a 2002 or E21 4 speed will bolt onto the 5 speed, but I don't know that for sure.
I do know for sure that some 1980 model 320i's (or possibly all 1980 models) had a 5 speed with the 4 bolt flange on it, and that you can easily swap that flange onto a later G245 5 speed.
The flanges are interchangeable. I've a 4 hole early flange on my 82 3-piece trans using the 8hole guibo. Was the shafts I had with 4hole and the 83 ltw 2piece trans ate itself. As they say the 83 trans was featherweight but failed with hard use.
88 M3
91 318is
91 318i
83 320is
08 X3 3.0si
