Results 1 to 7 of 7
Thread: Timing Chain Oops!
    Sep 2008
    RPV, CA
    '79 320iS
    Unhappy Timing Chain Oops!
    I replaced the head gasket on my e21 and followed the manual when reassembling it. I was careful not to let the timing chain slip off the lower sprocket. However when I followed the manual I thought I had let it slip and changed it by one tooth according to all the instructions, TDC, mark on crank pulley and distributor all aligned. I shoulda left it alone. Now I think it's "running" one tooth off.
    My question is this: How do I get it back to the right timing?
    Do I have to pull the head or should I pull the lower timing cover? How will I know when I have it right?
    Craigster 1952
    '79 320IS
    I know that car doesn't really exist.
    Just being provacative.
    Aug 2001
    NC
    E30M3,318is,318i,E21320
    Just undo the front top timing cover. Roll over and see if lines up. If not can just undo the tensioner to get slack. Then undo and move the cam gear again. Put the tensioner back in and roll over 2 times see if lines up straight. Gear should be inline with the oil bar. Crank pulley line with pointer.
    88 M3
    91 318is
    91 318i
    83 320is
    08 X3 3.0si
    Orange Beach, AL
    '06 525i
    One tooth off and you probably lucked out like me without having valves hitting pistons.
    Did the same thing and when I restarted had the SMOOTHEST IDLE...at like 250rpms.
    LOVE THIS CAR!!!
    2008 Sequoia
    2001 E55
    1998 M3 (RIP thanks to Hurricane Sally)
    1982 320i (ditto)
    2006 525i
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Always Triple verify the cam/crank timing marks by turning the engine BY HAND in normal rotation direction (CW from front). The ignition distributor orientation is set last.
    * Stop turning if there's any binding! (ie: pistons hitting valves)
    Your '79 probably has two marks on the cam sprocket, use the mark with the #2 stamped next to it.
    click to enlarge
    TDC Compression! stroke #1 cyl. After verifying cam/crank timing marks, set the ign distributor to this orientation:
    click to enlarge
    I confess I once had mine a tooth off as well, it idled like crap! I was like: how did I manage to do that ???
    Tbd
    Sep 2008
    RPV, CA
    '79 320iS
    Thanks Guys,
    I had it apart and the chain was tight even with the tensioner spring removed completely. I'm afraid I won't be able to get the sprocket off the cam shaft. Have any of you experienced that?
    Craigster 1952
    '79 320IS
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Quote Originally Posted by craigster View Post
    Thanks Guys,
    With the tensioner removed, the chain may be tight on one side and loose on the other side. Is this the case? - if so, you probably just gotta turn the crankshaft a teeny-tiny bit to release tension on the tight side of the chain.
    *set the crank/cam timing marks TDC compression stroke #1 before removing the cam sprocket (or close as you can get it).
    Tbd
    Pioneer, CA
    73' tii 79 320i 73'2002
    The cam springs will keep it tight at various positions, except #1 TDC. much easier to remove/adjust at that orientation.
  1. Knock Fault and Timing Chain
    By Lopaka in forum 1992 - 1999 M3 (E36)
    Last Post: 03-29-2006, 09:44 AM
  2. Pic of my timing chain and DIY timing chain instructions?
    Last Post: 04-16-2002, 09:20 PM
  3. need primary timing chain tensioner part no!
    By rpM in forum 1992 - 1999 M3 (E36)
    Last Post: 01-29-2002, 03:21 PM
  4. Timing Chain?
    By Breyton E36 in forum 1991 - 1999 (E36)
    Last Post: 08-10-2001, 04:13 PM
  5. M50/TU Timing Chain Q:
    By Lito Reyes in forum 1991 - 1999 (E36)
    Last Post: 03-09-2001, 05:15 PM
