No matter how much I search.. I can't find a picture, diagram or video with a transmission exactly like what mine looks like.
Think I have the GM automatic transmission THM R1 (MAYBE) Pics included
Mine appears to be missing a fill hole. Anyone have any ideas?
Was told to ask for Shogun cause Runoutmick said he's the BMW God!
here are all fill and drain plugs shown, ZF 5HP30, 5HP24, 5HP18, 4HP22 and 4HP24 have a dipstick from top, and also shown GM THM R1 (A4S 310R +A4S 270R) and 5L40-E (A5S 360R)
http://www.europeantransmissions.com...ansService.pdf
http://www.bmwe34.net/E34main/Mainte...0Autotrans.pdf
http://netisak.lpru.ac.th/bmw_e34_di...pplication.pdf
What is the VIN of your car?
The links below are pict of my transmission pan and you can see it looks exactly like the THM R1, except the fill plug is not there...
https://i.imgur.com/ABGdhzE.jpg
https://i.imgur.com/s3RH2XD.jpg
https://i.imgur.com/IVLTACs.jpg
vin WBAHD6315NBJ69776
Looks like I didnt post the link correctly... but if you copy the text and post it in the address bar it works that way. hank you SHOGUN
Based on the VIN this is the oil pan http://www.realoem.com/bmw/enUS/show...diagId=24_1299
item 9 24111218900 is said to be the drain plug , Transmission Drain Plug, Located on the rear of the transmission pan https://www.ecstuning.com/b-genuine-...g/24111218900/
item 11 Screw plug 24111219749 https://www.ecstuning.com/b-genuine-...g/24111219749/
so this one https://i.imgur.com/s3RH2XD.jpg https://i.imgur.com/ABGdhzE.jpg
here where I live we mainly have ZF transmissions installed or JATCO, so better someone more familiar with GM can chime in.
Imgur pics work, first time it says no access, but when I click reload and can see the pics
here it says: (As of 02/91 the THM R1 transmissions are not equipped with a dipstick) http://forum.e46fanatics.com/showthr...6&pp=20&page=2
yours is production month 07/1991! Does it have a dipstick? Then you could fill from the top(?)
The image you linked "so this one" is 9 on the diagram.. there is no number 11 as seen in the other 2 pics
I'm confused as mine looks just like the diagram you shared.. but look in the link below.. i labeled it
i labeled it here to show you there is no fill plug... https://i.imgur.com/tQYxJhM.jpg
No dip stick either.
No dipstick... Thanks for trying to help shogun..
have to wait till someone chimes in with GM trans knowledge, also this BMW tech info shows the fill hole there at the pan http://www.bgdiagnostica.com/BMW_SER...%20REVISED.pdf
Crazy.. maybe the previous owner replaced the pan with an incorrect one since its not on mine.. Or maybe the plug is missing and my hole is just filled and leveled with grim and dirt.. I'll have to look again in the morning .. thank you again
Looks like you have a piece of hose over the shift cable. Is the fill plug lurking behind that?
It's right above/behind red rubber cover. I had to remove cable to get fill hose in.
In this image you can see that there is no plug behind the cable/hose.
No, on this picture you can't see anything. Get under, clean area around red rubber with break clean and you will see it.
On mine it's here, visible. Maybe they installed blind plug and it is covered in dirt? I would clean it first.
https://www.pelicanparts.com/BMW/tec...Auto/pic18.jpg
