Results 1 to 18 of 18
Thread: Power steering pump needs replacing
    Jan 2017
    New Jersey
    1991 BMW 850i
    Hi Guys
    Where should I buy a power steering pump for my 87 325I Convertible?
    1991 BMW 850i
    1984 Porsche 928S
    Oct 2003
    Seattle
    99 M3
    www.car-parts.com?
    I think the p/n you are looking for is 32411141243.
    It also looks like there is a rebuild kit, p/n 32411133023 for a Vickers brand pump (I guessed at a 06/87 build 325i Convertible Automatic in www.realoem.com - use the last seven of your VIN to determine the actual pump installed in your car)
    Rebuild kit for ZF pump, p/n 32411135880.
    As indicated below, buy a used ZF pump and associated brackets, rebuild the pump (seal kit only) and install.
    Nov 2009
    Des Moines, IA
    90 ix, 91 i & ic, 02 325
    I would also check a salvage yard, I would have an issue going used - maybe even Ebay..
    Jan 2017
    New Jersey
    1991 BMW 850i
    I dont want to go with remanufactured.
    Any recommended brands?
    1991 BMW 850i
    1984 Porsche 928S
    richardodn's Avatar
    richardodn is offline Old Guy BMW CCA Member
    Moderator
    Nov 2008
    Lakewood, CO
    20 440ix cab, 12 X3 35ix
    First determine if you have a ZF or Valeo pump. The Valeo pumps are pretty uncommon. If you have a Valeo, you're better off converting the brackets to the ZF style. As for brand, ZF. As for remanufactured, it's really just clean and a seal kit.
    "Howdy, Folks!"
    Jan 2017
    New Jersey
    1991 BMW 850i
    Thanks Richard
    Is it east to determine what kind of a pump I have?
    So reman. is ok ?
    Thanks again
    1991 BMW 850i
    1984 Porsche 928S
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    First of all I erred. It's Vickers (LuK) and not Valeo. Everything else still applies. I've done a reseal kit on my wife's 528e in my driveway. That was well over 100,000 miles ago and still no leaks.
    To tell the difference, here's a few visual cues
    1. Nameplate: Vickers or LuK vs ZF is the best way
    2. Number of ribs on the "snout": Vickers has 4 while ZF has 12
    3. Pulley mount (hard to see while on car): Vickers is round while ZF is triangle
    If it turns out you have the Vickers, swapping to the ZF is pretty straightforward. Hose connections can be swapped over. Brackets are slightly different so there's a couple you would have to pick up.
    This is a messy job, so you might as well do these at the same time so you only have to clean up once.
    1. Flush the old oil out of the system.
    2. New supply and return hoses with new OE clamps. I think your year uses the bulk hoses so this is pretty cheap.
    3. Replace the reservoir as it has a built in filter. New versions have CFH 11.S embossed in the fill cap instead of ATF. Reuse your old cap but swap the o-ring over from the new one. You can also clean and reuse the old one but I'd still recommend replacing the o-ring.
    "Howdy, Folks!"
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    I did a search on that number. Amazing difference in price from almost a $1000 on amazon to $80 on Ebay (new). Ebay here I come. https://www.ebay.com/itm/New-Power-S...haBxIX&vxp=mtr
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    Do you realize that is not a ZF pump? It's the ZF style but likely a Chinese knockoff. I'd personally rather get a rebuilt original ZF part.
    "Howdy, Folks!"
    Dec 2012
    Grandview, MO
    1989 Bmw325IC
    Yes, I know it's a probably a Chinese knock off. It's really pot luck on Chinese stuff. Some is OK, some not. A lot of replacement parts for cars are Chinese. Most replacement brake disc's are Chinese. I've had fairly good luck on Chinese stuff. Depends on your budget and use. Do you take the chance?
    Jan 2017
    New Jersey
    1991 BMW 850i
    Oct 2003
    Seattle
    99 M3
    TRW is (was) an American manufacturer of American car OE and aftermarket parts. As a young adult, I had good luck with them on my ‘55 Chevy....fast forward fourty years and they are a subsidiary of ZF_Friedrichshafen.
    May 2005
    Houston, TX.
    15 X5, 02 330i, 09 MiniS
    I'd go with a good used pump over a new Chinese knockoff any day.
    I just rebuilt a 25 year old ZF for my 91 318iS yesterday with the 32411135880 rebuild kit. I'd already opened it and saw the vane pump, cam housing were in perfect shape so there was no reason not to. I also vapor honed the housing and had all the hardware yellow zinc choromated.
    Tenured Automotive Service Professional - Avid BMW Enthusiast
    richardodn's Avatar
    Moderator
    Nov 2008
    Lakewood, CO
    I'd also go with the TRW reman part. But if you really wanted new, Vaico isn't a bad choice.
    "Howdy, Folks!"
    Jan 2017
    New Jersey
    1991 BMW 850i
    Thanks guys
    1991 BMW 850i
    1984 Porsche 928S
    Dec 2014
    Canada
    72 2002tii 97 M3 87 325i
    Nothing wrong with a good well made rebuild unit, but as mentioned earlier, replace all the hoses and use new clamps.
    Dec 2021
    Finland, Lappeenranta
    1984 E30 323i
    I've seen two different kind of pulleys in ads for M20 power steering pump. One is with offset and one is "flat", what's the difference?
    Regina, Sask, Canada
    82 320i 89 325i
    Quote Originally Posted by MikkoRan View Post
    there are two different pumps. bmw did not make them. they used two different companies. the pulleys and mounts are different between them.
  1. Good Used Power Steering Pump Needed:
    By E24ureka in forum 1976 - 1989 (E24)
    Last Post: 12-10-2012, 03:09 PM
  2. Replacing Power Steering Pump Need help on DIY
    By tk7294 in forum 1999 - 2006 (E46)
    Last Post: 05-12-2009, 12:24 AM
  3. Power Steering pump needed 2002 540i
    By m5hoot in forum BMW Parts Wanted
    Last Post: 03-08-2009, 11:21 AM
  4. Power Steering Pump -- need help ASAP
    By T///Mac in forum 1991 - 1999 (E36)
    Last Post: 01-10-2009, 02:13 AM
  5. zf power steering pump- bearing replacement anyone?
    By wanganstyle in forum 1992 - 1999 M3 (E36)
    Last Post: 01-18-2008, 09:23 PM
