Results 1 to 25 of 32
Thread: m50 manifold conversion for FI
    San Antonio
    2002 bmw m3
    What setups are you guys using for m50 manifold installed on a FI setup? I have seen someone mention getting fittings from Home Depot and DIY it, but the TRM kit looks like it has everything put together.
    Pics of setup would be much appreciated. I want to delete my CCV as wel.
    Manchester, N.H.
    96 332IS 6466 turbo
    Here is my good deed for the day. Sharing is caring.
    Pex/shark bite fittings ^^
    Sent from my E6782 using Tapatalk
    1996 332IS
    Built 3.2
    Technique Tuning 80# tune.
    1/4 mile 10.84 @ 136.72
    WWW.CESMOTORSPORT.COM
    NY
    skateboard
    Fancy
    ― George Orwell
    Mar 2011
    Kingston ,Jamaica
    1997 328i turbo
    I liked your Meth setup
    Manchester, N.H.
    96 332IS 6466 turbo
    Liked ? Past tense ?
    1996 332IS
    Built 3.2
    milKt's Avatar
    milKt is offline ßMW///MµrÐêr§þðr†
    Flaccid US Appendage
    95M3t 95M3 92525iT 95525
    Been holding 15-19psi for years.
    Stock ... w/ "helper" + JB weld
    Jul 2004
    Austin, TX
    AA turbo 332i
    Epoxy everything that “clips” especially the icv area. I did this + zip ties so no funny business and even filled in the useless plastic barb for the oem oil separator and also filled in the clip in recessed barb for the FPR.
    Someone also makes an aluminum replacement for the icv clip-in piece, not sure who but it looks slick.
    Invest in the silicon boost-proof icv setup from Max PSI as boost leaks below the mani are frustrating.
    Though pictured, I regret doing the bottom rear barb for the oem FPR since I went to an aftermarket one up front... just extra hose now
    1995 325i | OBD1 S52 | S50 cams | AA Turbo TD06 20g / 42lb / Porsche maf | .140 MLS | F1 s3 clutch | Ultimate SSK | AKG 75D subframe/diff bushings | 3.23 LSD | Powerflex LCAB/RTAB | e46 fca | Raceland coils | BMP rear arms | DEPO HID | AEM Failsafe | Aeromotive FPR | Walbo 255 | 3" Magnaflow muffler/cat/res | 17x8.5/9.5" 225/45 & 255/40
    Aug 2008
    Australia
    BMW Z3
    One thing i did i removed the plastic thats inbetween the length on the runners i just used a dremel and some sand paper. Its been like this for 10 plus years and it has not not caused any stress cracks or fractures. I thought it might help with any hot air thats trapped under the manifold.
    Virginia
    97' m52 turbo
    Quote Originally Posted by jjjjjjj View Post
    I originally put a barb on the underside like you and I regret it. Once you start boost leak testing those are going to be really hard to hear or spray soapy water on to observe for leaks.
    Its best to make them as accessible as possible for that reason alone.
    Butters placement is probably ideal with all three near the brake booster line.
    If you need an additional spot, you could use the front foremost of the manifold where there's that little circle that looks like a star for the BOV. Its on the side facing the front of the car when the manifold is installed. see pic
    images uploader
    Jul 2004
    Austin, TX
    AA turbo 332i
    Nice! Yes that’s a good spot up front, next time I pull the mani had planned on tapping that spot to run to the FPR and seal up the old spot in the back.
    Virginia
    97' m52 turbo
    Yup,
    took me 3 manifolds before to get where I'm at now and I still have leaks. Drives me crazy. Epoxied ICV connector is leaking now
    Going to be picking up a forth for the last time here soon.
    Oct 2003
    Seattle
    99 M3
    There have been several attempts at building full aluminum intake for FI, any success stories out there?
    Virginia
    97' m52 turbo
    Quote Originally Posted by bluptgm3 View Post
    Aluminum really isn't needed.
    Guys here pushing crazy boost on 20 year-old plastic m50 manifolds and they hold up fine
    I see an alum mani on ebay every once awhile. Price is always outrageous though.
    Jul 2004
    Austin, TX
    AA turbo 332i
    Hop over to boosted fb world, pretty hot topic. There’s a sick billet one for $3k and a knockoff for $ .3k
    Seems unnecessary under 30psi / 1000whp is my understanding
    Virginia
    97' m52 turbo
    I try to stray away from FB.
    I get aggravated on there
    milKt's Avatar
    KorreCT
    Jul 2004
    Austin, TX
    AA turbo 332i
    I forgot the “lolz”. Agreed
    Virginia
    97' m52 turbo
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Here's a dumb question: At what power level does the step from the M52 manifold to the M50 manifold really begin to pay big dividends with a turbo?
    It's a foregone conclusion that you should always swap, but at low power levels so far my M52 manifold seems great. The engine seems to make really nice power for such low boost as I've been running, and the responsiveness is very nice.
    May 2017
    Miami
    99 323I Conv
    Quote Originally Posted by tptrsn View Post
    at any power level
    DeWitt, Michigan
    Can you be more detailed about this? It's hard to know from that if you have good information, or are just trolling.
    Manchester, N.H.
    96 332IS 6466 turbo
    The big gains are at higher RPM. Your turbo car will feel fast, well cause its a turbo car. But the m50 flows an ass load more air than the m52, so at higher rpm, your power will continue to rise where your m52 manifold is choking in comparison. Let er eat ! Air and fuel.
    1996 332IS
    Built 3.2
    Virginia
    97' m52 turbo
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    Wow, shipping is only $190USD
    Mar 2012
    Renton, Wa
    98 m3
    To help with reducing leaks over time install nipples in stiffer areas. Less flex, less leak.
    Yes the m50 swells.
    I like installing nipples at the front corner between the ribs. Epoxy with npt. Use a step-less bit and then run the npt fittings in with a drill.
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
  1. Replies: 6
    Last Post: 07-22-2008, 12:57 PM
  2. ***NEW*** Throttle Body Seal for the M50 Manifold Conversion
    By E36M3E in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 04-06-2007, 06:57 PM
  3. For Trade: M50 Manifold Conversion kits
    By E36M3E in forum BMW Parts For Sale
    Last Post: 11-26-2006, 06:38 PM
  4. ***NEW*** Throttle Body Seal for the M50 Manifold Conversion
    By E36M3E in forum Vendor Comments & Supporting Vendor Info
    Last Post: 09-04-2006, 07:15 PM
  5. What parts are needed for the M50 manifold conversion on the OBD2 M3's
    By Daydream M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2004, 04:15 PM
