Page 2 of 2 FirstFirst 12
Results 26 to 32 of 32
Thread: m50 manifold conversion for FI
  1. #26
    DeWitt, Michigan
    '97 540i/6, '97 328i
    Quote Originally Posted by Butters Stoch View Post
    The big gains are at higher RPM. Your turbo car will feel fast, well cause its a turbo car. But the m50 flows an ass load more air than the m52, so at higher rpm, your power will continue to rise where your m52 manifold is choking in comparison. Let er eat ! Air and fuel.
  2. #27
    Virginia
    97' m52 turbo
    Quote Originally Posted by wgknestrick View Post
    Wow, shipping is only $190USD
    Lol, yea...
    I haven't been able to find a reasonably price reinforced manifold in the US
    Quote Originally Posted by vollosso View Post
    To help with reducing leaks over time install nipples in stiffer areas. Less flex, less leak.
    Yes the m50 swells
    I like installing nipples at the front corner between the ribs. Epoxy with npt. Use a step-less bit and then run the npt fittings in with a drill.
    Yes they do,
    I've seen mine completely flex at an idle rev. Can't imaging what it looks like under pressure
  3. #28
    Feb 2018
    Orlando, Florida
    '86 BMW 535 (m52)
    Liked ? Past tense ?
    Sent from my E6782 using Tapatalk
    That's an awesome setup for meth! Did you do it all DIY? Also at what power point would this kind of setup be worth it?
  4. #29
    Virginia
    97' m52 turbo
    Quote Originally Posted by E34Dave View Post
    Yup
    Butters has one the coolest manifolds I've seen on heya
  5. #30
    Jan 2006
    Oakhurst, CA
    96 M3 97 M3 98 M3 99 M3
    I used the reboot engineering M50 aluminum adapter. The OEM rubber neck was on this one but I've also used MaxPSI hoses too. http://rebooteng.com/parts/m50-intake-manifold-fitting/
  6. #31
    Jan 2021
    Ny
    94e36, 00e39 532it turbo
    Turbo car, swapped m52 to m50 intake. Went from 450hp at 20 psi to 530 at 21 psi? (Somthing like that)
    Seems like the m50 is well worth it if your boosted.
    https://youtu.be/FsqZiWxLI8M
    Tips for m50 manifold + f/I.
    https://youtu.be/cYoU6axywXU
  7. #32
    Feb 2017
    Raleigh, NC
    1998 M3 643whp
    Quote Originally Posted by Braymond141 View Post
    These are pretty good,
    If you get the RallyRoad version, make sure you ditch the zip tie that comes with it.
    https://rallyroad.net/collections/fo...ld-icv-fitting
    Replace Zip Tie with a skinny SS Hose clamp. My zip tie stretched and allows the barb O-Ring to break seal when the barb gets to a certain angle inside the ID of the M50 port. It's due to only having 1 attachment holding the thing together.
  1. Replies: 6
    Last Post: 07-22-2008, 12:57 PM
  2. ***NEW*** Throttle Body Seal for the M50 Manifold Conversion
    By E36M3E in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 04-06-2007, 06:57 PM
  3. For Trade: M50 Manifold Conversion kits
    By E36M3E in forum BMW Parts For Sale
    Last Post: 11-26-2006, 06:38 PM
  4. ***NEW*** Throttle Body Seal for the M50 Manifold Conversion
    By E36M3E in forum Vendor Comments & Supporting Vendor Info
    Last Post: 09-04-2006, 07:15 PM
  5. What parts are needed for the M50 manifold conversion on the OBD2 M3's
    By Daydream M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-11-2004, 04:15 PM
