Results 1 to 3 of 3
Thread: 3 out of 7 warning lights work on "Test" of Active Check Control
    Jun 2006
    Wadsworth, Ohio
    77 BMW 730i
    When I depress test only 3 out of 7 lights work on my Active check control. Bulbs are fine and all the bulbs are getting power, any idea's?
    Feb 2009
    Pittsburgh, PA
    '86 635CSi, '08 128i
    You have the LED type Check Control unit, right? I might have a good board around, I can check if you're interested.
    **Edit** Nevermind that, you have the older type unit. I'm not sure how to troubleshoot that one. I'd presume the controller has some problems. I took a look at RealOEM but couldn't make heads or tails of the older CCC unit. Here's a link. I would think that's driven by a controller of some sort, but the diagram isn't clear.
    Jun 2006
    Wadsworth, Ohio
    77 BMW 730i
    Thanks for the response @desktopDave, yes not a LED unit, standard bulbs. I am at my whits end, I have worked on BMW's for 20 years and never seen one act like this. The circuit boards are NLA so will have to purchase a used from Ebay I guess as a way of diagnosing it. Need one with German writting though since it's a euro spec car
  1. Just changed front brake pads...brake warning light stayed on
    By BMR616KC in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-03-2020, 05:35 AM
  2. Replies: 4
    Last Post: 08-09-2013, 04:17 PM
  3. Will the HFM out of my 740 work on my M roadster?
    By Darkness in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 11-26-2004, 10:13 AM
  4. Brake warning lights till on????
    By Ali in forum 1991 - 1999 (E36)
    Last Post: 09-16-2001, 11:53 AM
  5. One of my lights came on....
    By AlphaKennyOne ///M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-25-2001, 08:52 AM
