When I depress test only 3 out of 7 lights work on my Active check control. Bulbs are fine and all the bulbs are getting power, any idea's?
You have the LED type Check Control unit, right? I might have a good board around, I can check if you're interested.
**Edit** Nevermind that, you have the older type unit. I'm not sure how to troubleshoot that one. I'd presume the controller has some problems. I took a look at RealOEM but couldn't make heads or tails of the older CCC unit. Here's a link. I would think that's driven by a controller of some sort, but the diagram isn't clear.
Thanks for the response @desktopDave, yes not a LED unit, standard bulbs. I am at my whits end, I have worked on BMW's for 20 years and never seen one act like this. The circuit boards are NLA so will have to purchase a used from Ebay I guess as a way of diagnosing it. Need one with German writting though since it's a euro spec car
