So, the S54 is planted in a 2001 E46 325iT. Car runs, low oil and battery lights resolved. Now for the REAL fun ....
The ABS systems are different. How can I resolve the ABS and DSC fault lights on the dash? I really want the dash clear, and all systems working.
S54 swap DME flashing - $100
S54 swap CAN interface board (for proper A/C & check engine light) - $275
e36 SAP sim/secondary air pump simulator: $75 - standard or $170 - plug & play
e36 post-cat O2 sims: $115 shipped, plug & play
I did not swap the ABS as the donor car was to be used for an LS swap. As for codes, not yet. Been busy with all the engine codes and lights. Now that they have been resolved, the car is out for a custom exhaust, and then I will dig into the ABS and DSC lights.
PS. If the ABS unit needed to swapped, is sure would have been easier with no engine in place !!!!
