Hi,
My X5 4.4 has 194k, v/c gaskets,plugs,water pump/hoses only thing ever done to engine.
I need to replace the trans (chatter 1st-2nd) and do the intake gaskets, valve cover gaskets, vanos, timing chains/guides, oil pump chain which are way over due!
The engine shows typical oil and antifreeze leaks at rear,
What is involved in dropping the whole unit out the bottom?
Shops are quoting 32hrs $4500.00.
GG
Go thru my thread. Just did it. https://www.bimmerforums.com/forum/s...Black-on-Black
