Results 1 to 7 of 7
Thread: How do get builders sheet or info
    Jan 2018
    Houston
    Bmw
    I have a 1982 635CSI alpina Euro I知 trying to get all the Information on it to insure this is the car. I知 having no like from other sites everything on the car is in German.
    1982 635 CSI ALPINA EURO (white)
    VIN-TP49170
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    If it is an Alpina, contact Alpina directly for the build sheet, with the Alpina VIN you do not get any data out of the BMW system. But there must be also the BMW VIN, that you can try here, that shows you how it went from BMW to Alpina
    http://bimmer.work/
    hope that VIN decoder also works for the E24
    where to find the VIN https://www.bimmerforums.com/forum/s...86-E24-M635CSi
    Jan 2018
    Houston
    Bmw
    Jan 2005
    Japan
    That is the frame number TP4-9170, built year 1984, model 6CS/1
    since around 1980 almost all VIN numbers of all makers are 17-digits, also BMW. The VIN number of your car starts with WB......check on the right side front shock dome.
    For example here is one shown WBAEE310801051230 https://www.etkbmw.com/bmw/EN/vin/decoder/1051230/ZH
    North Alabama
    Look on the firewall and door frame for the vin.
    If you can get me the vin I can run it through BMW and Alpina and tell you exactly what you have.
    Aug 2008
    Sydney Australa
    1x633, 1x E3 2 DR Racer
    Th vin should be on the top of the block on a flat section of steel above the starter motor.
    1977 633 CSi RHD Euro. S38B38 3.9L M5 Transplant. 5 Speed Getrag Dogleg. 3.73 LSD. 417hp, 369lb/ft
    1971 3.0CS E3 2dr Alpina Special Coupe Racer, 347hp, 295lb/ft
    Oct 2018
    Downers Grove, Ill
    1988 BMW M6
    This same car is now for sale in Illinois. Did you ever find any more info on the VIN number? I did check all the usual locations and couldn't find the other VIN number.
  1. Replies: 38
    Last Post: 12-14-2007, 10:32 AM
  2. How do yo uadd picks and info bought your car
    By Zippylock in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 02-04-2006, 07:33 PM
  3. How do get rid of steering wheel shine??
    By Bruse Wayne in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 05-22-2005, 05:16 PM
  4. How do I clean this or re-blacken it?
    By beyondweb in forum 1991 - 1999 (E36)
    Last Post: 09-05-2004, 01:22 AM
  5. How do get started?
    By TheBestCow in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 07-19-2002, 07:21 PM
