Results 1 to 7 of 7
Thread: Odd No Start/No Crank Battery Drain Issue
    Jan 2018
    Tazewell, Tazewell, VA
    2005 325ci
    Hello...I hope someone can shed some light on a problem I'm having with my beloved 2001 325ci. Several years ago, I replaced a battery, then another, and now another in response to a intermittent no-start/no crank problem. Certainly seemed like something was draining my battery. I've also replaced the alternator and the ignition switch. (When the issue occurs and I turn the key, I get lights and hear various items whirring, but it never cranks...however...I can roll or push start the car.)
    I've read and thought quite a bit about this, and I'm wondering...could this be a bad starter?
    Thanks in advance for any help anyone can provide!
    Muddywolf
    "The blues had a baby and they named it rock and roll." McKinley Morganfield
    Dec 2013
    Chicagoland area
    EXOTICS
    Since you have replaced the alternator and ignition switch, along with multiple batteries,
    I would certainly suspect a faulty starter solenoid.
    You can try to confirm the next time the issue occurs,
    by attempting to start - while someone knocks on the solenoid with a wrench.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    The battery draining issue needs to be addressed. Also, a lead acid battery's lead plates can be physically damaged by repeated deep discharging. The result is the battery has a lower capacity.
    The battery drain can be caused by the final stage resistor (FSR). The FSR is used by the climate control (IHKA) to vary the speed of the cabin climate fan. Does your fan act irrationally? So, pull fuses 28, 62 & 63 to see what happens. If that doesn’t stop the battery draining you’ll have to use a digital volt/ohm/ampere meter to determine the source. Basically, the meter, set up to read amps, is connected to the ground cable and the battery’s ground lug. The car goes to sleep and you check the reading. It needs to be less than 70ma. If it’s appreciably higher, start pulling fuses one at a time.
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    Does the car go to sleep? The only real option you have is a amp draw test either a meter or oscilloscope which for me works better... asking for quick help online only lead tto more gray hairs and an empty wallet. On a 46 the first thing I start with on a draw is the final state
    Buy my native installed ISIS ISTA-D/ISTA-P bmw diagnostic laptop. More Info Here!
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I think Driiven means the final stage resistor (FSR). It’s part of the hvac system for the passenger cabin. Basically, the automatic climate control (IHKA) uses the FSR to provide a wide variety of fan speeds. The symptoms of a bad FSR include erratic fan speeds. However, the FSR is known to fail and drain the battery.
    The best way (imho) to find a power drain is to connect a digital volt/ohm/ampere gauge in series with the battery. That is, remove the ground cable and connect the meter’s lead to the cable and the battery post. Set the meter up to read amps. DO NOT ATTEMPT TO START THR ENGINE. Allow the car to go to sleep and check the meter. The current draw should be less than 70milliamps (0.070 amps). Start pulling fuses one at a time if it’s higher than that. Happy hunting.
    o
    Jun 2005
    Dirty MFin Jersey
    M3 Buildup
    yeah final stage, stupid ios autocorrect
    Dec 2013
    Chicagoland area
    EXOTICS
    Parasitic battery drain diagnostics:https://www.youtube.com/watch?v=QRso1A0VScw
  1. '91 318is No Start / no crank / no blower / no CEL issue
    By nanotech9 in forum 1983 - 1991 (E30)
    Last Post: 11-25-2017, 11:57 AM
  2. No Start/ No Crank 1997 328is Issue
    By Ck223 in forum 1991 - 1999 (E36)
    Last Post: 11-20-2017, 04:33 PM
  3. Another E36 intermittent no start no crank issue...
    By AlpinweissE36 in forum 1991 - 1999 (E36)
    Last Post: 10-26-2017, 10:59 PM
  4. Replies: 9
    Last Post: 12-26-2010, 12:59 AM
  5. Need Help!! Crank No Start!! No Engine Light!!
    By ALLADULTVIDEO in forum 1992 - 1999 M3 (E36)
    Last Post: 02-19-2008, 09:01 PM
