Results 1 to 3 of 3
Thread: e46 swapped dme eprom with newer model need to know which to flash it with
    Jan 2018
    okc
    323i 99 325i 04
    Ok so i had a 7533652 gen pn
    prog 7548093
    took to electronic guy he used ir and took off old eprom put on new dme
    dme part general number 7548770
    it was prog on label with 7549093
    They both are ms 45.1 boards are a little different the new one from junk yard is a little different updated hardware
    I found that when looking up the vin it was same year model of car just had a m56 motor where mine has m54
    I have it working i can inpa dis into it and diagnos it says in inpa
    error 1(3) nr: 12186 ffff unknown error location
    error 2(3) nr 10039 2737 ews 3.3 manipulation protection
    error 3(3) nr: 10368 2894 irreversible ecu errror
    car cranks does not start
    I dont think i just need to flash ews may need to update dme to right prog for updated gen pn
    can some expert please help me or am i lost do i need to find new ecu and take to electronic guy to have him transplant eprom in same as orig part number?
    Jul 2004
    Houston, TX
    36 Cylinders
    1. You cannot swap eeproms on that DME. Only a BDM read can do what you need on MS45.0/.1.
    2. You ABSOLUTELY need to put in an MS45.1 if yours was MS45.1. But it shouldn't matter what part number.
    I have a spare MS45.1 that I can prepare for you.
    If your original DME is still somewhat workable on diag line, send it to me and I can get it all done. Send me a PM with your email address.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2021
    Upland, CA. 91786
    2005 BMW 530i 3.oL
    Hey, "328 Power 04"from Houston - I have been continously searching & clicking on possible solutions to a BMW DME issue which parelles trfpdr DME issue with Eeprom swap to a Donor DME MS45.1 on my 05 - 530i 3.0l which also resulted in a crank but No Start. I am having trouble in sourcing out a resonable solution that can meet my finicial situation.. I am hoping to get some more indepth info from you as to help me chose what i need to do to fix my car.. please thanks and sorry for the intrusion upon this old thread, but i just read your responses & felt i should try and take a risk at reaching out.. i appologize if im in the wrongs or violating any forum rules..
  1. Low mileages vs high mileage with newer model??
    By lcruiser in forum 1996 - 2003 (E39)
    Last Post: 07-23-2011, 10:31 AM
  2. Replies: 2
    Last Post: 07-14-2007, 03:07 AM
  3. Replies: 100
    Last Post: 03-07-2007, 12:48 PM
  4. need to know what to clean this with...
    By Cosmos96 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-20-2005, 10:46 PM
