I did not grow up with BMWs. I am reading posts here and learning lots. I searched, but could not find a list that explains the various abbreviations and engine code you guys use so easily.
Is there a list...i need a decoder ring!
I know I've typed this before, but don't know where it is.
Chassis: E36/7 (roadster), and E36/8 (coupe). It's a derivative of the E36 ('92-'99 3-series).
Engines (just US Z3):
M44B19 - 1.9L 4-cyl ('96-'98)
M52B28 - 2.8L 6-cyl ('97-'98)
M52tuB25 - "2.3" (really 2.5L) 6-cyl ('99-'00)
M52tuB28 - 2.8L 6-cyl ('99-'00)
M54B25 - 2.5L 6-cyl ('01-'02)
M54B30 - 3.0L 6-cyl ('01-'02)
S52B32 - 3.2L 6-cyl ('98-'00 M)
S54B32 - 3.2L 6-cyl ('01-'02 M)
Then there are all sorts of other acronyms for suspension parts and engine parts. I'll start with some that come to mind -- feel free to add to the list, everyone.
LCAB: (front) Lower Control Arm Bushing
RSM: Rear Shock Mount (top of rear shocks)
SAP: Secondary Air Pump
I like the unicorns.
'99 Z3 Coupe - Jet Black/Black (1-of-114)
'99 M Coupe - Estoril Blue/Black (1-of-82)
'03 540iT - Sterling Gray/Black (1-of-24)
'16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
RTAB: Rear Trailing Arm Bushing
Lollypop: Front Lower Control Arm Bushing Mount
Giubo: Rubber Drive Shaft Coupler (to transmission)
LSB: Laguna Seca Blue
FLCA: Forward Lower Control Arm or ‘Wishbone’
RTA: Rear Trailing Arm
‘Hat’ or ‘Spring Hat’: Upper Spring Plate -Front
NVH: Noise, Vibration, Harshness
There are three sets of acronyms in play.
BMW specific. Very precise, but sometimes don't make sense because they are German based. DME = engine computer
SAE. Again, specific and universal. This is what your scanner will show, and your mechanic will use. Rarely used in the forum
Forumspeak. This is a bunch of random letters strewn together based on what the poster thinks the part is called at the time. Ambiguous, vague, and sometimes contradictory.
/.randy
Some common forumspeaks:
NLA - no longer available
OP - original post (or poster)
AFAIK - as far as I know
IMHO - in my humble opinion
PITA - pain in the ass
LOL - laughing out loud
ROFL - rolling on the floor laughing
TU = Tango Uniform = broken
Tony
"You can't sign away negligence."
Beemer, We always used this back in the UK.
Seems to put US owners into some sort of fit.
Bimmer, As used by Americans.
RSFB: Rear Sub Frame Bushings
FI: Forced Induction
SC or S/C: Supercharged
SS: Stainless Steel or for some reason, Supersprint (which is one word)
VANOS: Variable Nockenwellen Steuerung, similar to variable valve timing (VVT) on "other" cars
DISA: Differenzierte Sauganlage, or a Differentiated Intake, Variable Intake, etc.
Style 40: OEM BMW wheel type on M Roadster and M Coupe
Style xx: many other BMW wheel options
TU: Technical Update, i.e. M52TUB28
DIY: Do It Yourself, not to be confused with DY (Dakar Yellow) or PY (Phoenix Yellow)
MR or Z3M: M Roadster
MC or Z3MC: M Coupe
RF: Randy Forbes
Nathan in Denver
W.W.R.D. - what would Randy do
And then there are the transmission types as well.
ZKE body control module
DSC dynamic stability control
BMW a manufacturer of fine garbage fires
EVAP Evaporative emissions system
Cat catalytic converter
Transmission types? I know 2.
4L30E a meh French-manufactured GM 4 speed transmission based on whatever the TH180 would be like with an extra speed literally bolted to the front of the case
5L40E the successor to the 4L30E; it's French as well
