Results 1 to 9 of 9
Thread: Low rumbling noise from transmission/drive shaft area
    May 2017
    Houston
    03' 540i, 05' 545i
    Good evening.
    Recently I have had an issue where I will hear a low growling/rumbling noise from underneath the console area while accelerating on 3rd-4th gear. After the noise is heard, I get a stutter in the power delivery, then the car accelerates as normal. This happens twice on each run to 60mph.
    It has proven difficult to hear the sound on the vid I made, so I decided not to upload it..
    Dec 2017
    Prijedor
    BMW 525d 2002
    It could be the pressure plate or flywheel. Try pressure plate by engaging in second gear with parking brake fully engaged, then slowly release clutch, it should stall if not, your pressure plate is worn out. If it is flywheel you should have some others symptoms as well ... like vibrations even when car is in neutral.
    May 2017
    Houston
    03' 540i, 05' 545i
    ZF tranny
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Either flex disc or the center support bearing. Sounds more like the center support bearing.
    May 2017
    Houston
    03' 540i, 05' 545i
    Sounds promising. When I look up the symptoms for center support bearing issues, the explanation sounds similar. Ill have it looked at this weekend to be sure.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I assume you've checked your engine and transmission mounts, too?
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    May 2017
    Houston
    03' 540i, 05' 545i
    Not yet. Is there a method to check it which is straightforward for a layman? I havent had the space to jack my car up in my garage (recently moved) so I have not done any heavy duty work which requires lifting the car up in a few months
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Quote Originally Posted by bimmer7410 View Post
    Lifting it is step one. The engine mounts, when bad, will have leaked a dark colored hydraulic oil, and will be significantly compressed. Trans mounts are easier to inspect visually, as they appear squashed if they’re worn out.
    Nate J.
    May 2017
    Houston
    03' 540i, 05' 545i
    I’ll be trying the above post out today.
    For reference, this video has the sound I speak of
    https://youtu.be/6LGyZGUAVWg
    I also get an RPM dip after each time the rumbling comes on.
    Finally, when accelerating slowly, the car jerks/shudders until gas is pressed more firmly.
  1. Clucking Noises From Transmission Area
    By Tromonine in forum 1991 - 1999 (E36)
    Last Post: 10-10-2014, 01:14 PM
  2. Odd noise from transmission area.. Throw out bearing? Vid included
    By bladsville in forum 1992 - 1999 M3 (E36)
    Last Post: 12-27-2012, 10:41 PM
  3. Low level gear noise from final drive while coasting, 04 M3 SMG
    By jetmech3421 in forum 2001 - 2006 M3 (E46)
    Last Post: 03-03-2010, 09:58 AM
  4. clicking nose. sound comeing from drive shaft area
    By dmess in forum 1992 - 1999 M3 (E36)
    Last Post: 02-14-2007, 10:29 PM
  5. Replies: 2
    Last Post: 06-03-2002, 05:08 PM
