Results 1 to 4 of 4
Thread: 1995 540i Transmission help
    Jan 2018
    Vienna, VA
    1995 BMW 540i
    I have an automatic 1995 540i. Just replaced the transmissions because it the housing was cracked and it wouldn't start. Now it will move but I think it skips over first gear. I can get it to roll as if not engaged and then it catches. Any ideas on what the problem is?
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E34 forum forum software forum
    Did you fill the ATF as per instructions? http://www.europeantransmissions.com...MWtechinfo.htm
    Oldham UK
    '00 330i Sprt '92 525i
    Do you mean it starts off in second instead of first or there is a delay/slip when you put it in drive? As Shogun says, first make sure it is filled correctly. Then double check you have adjusted the shift cable and that what you see in the cluster reflects the shift lever and mode switch postions
    Aug 2009
    Greeley, CO
    540i6, 540iA, RX7, RdBlk
    This sounds like the classic 5hp30 "valve body flaw" issue - it feels like it's powerbraking from a standstill for a few seconds, then it just lets go and accelerates normally? If so, do a subforum search for "valve body flaw" and it'll come up - it's something specific to early cars that had the 5hp30 transmission (540's and E32 740's). Can be fixed yourself as long as the reverse drum hasn't gone boom yet (you know because you wouldn't have reverse). I'll link a rebuild thread for the valve body when I find the one I did...
    K Fox
    *edit* Here's that link to the thread I was talking about...
    Last edited by K Fox; 01-23-2018 at 05:27 AM. Reason: found the thread (and fixed it)
  1. Thinking of buying 1995 540i need help pls ?
    By Rocketman17 in forum 1988 - 1996 (E34)
    Last Post: 04-12-2011, 04:14 PM
  2. Thinking of buying 1995 540i need help pls ?
    By Rocketman17 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-12-2011, 04:48 AM
  3. Looking at a 1995 540i Auto, help please!
    By ryan2022 in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 04-29-2008, 06:03 PM
  4. Transmission problems on 94 540i. Please help!!
    By zlh in forum 1988 - 1996 (E34)
    Last Post: 05-30-2006, 07:15 PM
  5. 1992 525i or 1995 540i need help in buying decision
    By gj1968 in forum 1988 - 1996 (E34)
    Last Post: 11-19-2005, 07:03 PM
