Results 1 to 6 of 6
Thread: Remote key wont unlock.. antenna?
    Dec 2017
    Prijedor
    BMW 525d 2002
    Remote unlock/lock wont work.
    Car starts normally.
    Manual lock/unlock door works.
    All fuses OK (fuse 53 checked)
    Inside car central locking (big button) works normal.
    Fuel door actuator works.
    Radio works normally.
    Here are some photos and questions if someone can explain.
    NOTE: I also measured with multimeter and it seems that i don't have 12 Volts in none of these wires.
    Here are the photos:
    https://imgur.com/a/YuEvA
    https://imgur.com/a/SysDK
    https://imgur.com/a/Mi2MC
    Any Ideas/Suggestions?
    Oct 2005
    Silver Spring, MD
    Too many
    Battery in your key? I'd check that first.
    Sent from my SM-T817V using Tapatalk
    00 740iS
    84 635 (euro)
    88 M6
    84 745i
    88 325iX
    92 850i (6 spd)
    Dec 2017
    Prijedor
    BMW 525d 2002
    Forgot to mention. New battery in both keys, tested and 3 Volts both. Also tested keys buttons. They work perfectly.
    I also know how to program keys, and i did that in past, but that didn't help either.
    Aug 2014
    Cheshire, CT
    1998 BMW 528i / 5
    How is the car's main battery? I believe the E39's have a failsafe where it won't let the remote lock work if the main car battery is low. It should be ~12.5v while in sleep mode.
    Ed CT
    1998 528i
    5-Speed
    Aspen Silver
    Aubergine Leather
    Dec 2017
    Prijedor
    BMW 525d 2002
    Bought brand new car Battery 2 days ago. 100 Ah. Everything else in car works perfectly.
    Mar 2012
    Hayling Island
    Alpina B10
    I had this, everything worked fine except the remote key locking. It turned out to be the bootlid wiring had chafed and broken in the rubber concertina where the boot wiring feeds into the car! Didn’t make any sense to me but worth a look.
  1. Need help, key wont unlock
    By etsmyers in forum 1988 - 1996 (E34)
    Last Post: 12-05-2016, 10:16 AM
  2. key wont unlock trunk
    By isaac86 in forum 1991 - 1999 (E36)
    Last Post: 04-04-2010, 09:28 PM
  3. Key wont unlock doors help?
    By Clint CatchM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 07-07-2009, 11:19 PM
  4. Remote PROBLEMS (wont unlock)
    By SiDeWaYZz28 in forum 2002 - 2008 (E65, E66)
    Last Post: 05-27-2008, 06:46 PM
  5. Remote key not unlocking the door
    By big1234 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-14-2005, 11:39 PM
