RM European Auto Parts
Results 1 to 12 of 12
Thread: Dashboard light 2 cars
    Nov 2013
    FL
    x5
    Cool Dashboard light 2 cars
    Dear All,
    Someone did a reset for the dashboard of my x5 2003 3.0i
    Then suddenly, I got a yellow light on the middle showing 2 cars
    i am unable till now to remove this light and it is really annoying me when driving at night
    Photo attached for more info
    dworthy's Avatar
    dworthy is online now Wagon meister :) BMW Tech Expert
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    What does your owners manual say?
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jul 2004
    Houston, TX
    36 Cylinders
    Active Cruise Control.
    You need a BMW oriented diag scanner to check and clear the errors in the whole car system.
    Not entirely sure by what was actually done for 'reset the dashboard' though.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Nov 2013
    FL
    x5
    Hey,
    the scanners are not showing this light as an error
    the manual has nothing about it too
    dworthy's Avatar
    Nov 2010
    What scanner are you using? If it happens to be a 2-dollar pocket scanner, well.....
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    i don't think a US market '03 X5 would have had active cruise - would it?
    Jul 2004
    Houston, TX
    36 Cylinders
    If that is the case, then it is a coding problem.
    -Abel
    Mar 2003
    St. Joseph, Mo.
    yup, agreed - or something like it. what in the world is a "dashboard reset" anyway? op? what was done to your instrument cluster?
    Nov 2013
    FL
    x5
    on dashboard you can reset it by using the two buttons and confirming in case one of the indicators was not working fine
    someone advise to take off the battery cables and then re-connect them, do u think this can help ? I am afraid to do so and end up with memory problems in car
    Quote Originally Posted by shadowpuck View Post
    dworthy's Avatar
    Nov 2010
    When you disconnect a battery in those cars, the most you will lose is the odo trip mileage. Now if the battery is off for say 20 minutes or more, then you tend to lose the station memory in the radio as well.
    Most modern BMW's, removing the battery will do nothing to reset the computers, as they don't have volatile memory like the OBD-I cars.
    I think you will need INPA or ISTA to fix the problem and see what code is setting the light.
    Darin
    Current:
    Past:
    M-Flight Member
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I've never ever seen that symbol. Certainly, there was no active cruise on a 2003 X5 that I've seen, at least.
    You need to talk to ALL the computers, with ISTA, Autologic, or some other top-quality diag computer. If it's a coding issue, as Abel suggests, you're going to need ISTA to fix it.
    Chris Powell
    BMWCCA 274412
    dworthy's Avatar
    Nov 2010
    That is why I had asked myself, for in that location the symbol is suppose to be the warning for the self-leveling suspension.
    Darin
    Current:
    Past:
    M-Flight Member
  1. Replies: 0
    Last Post: 02-20-2014, 04:25 PM
  2. blinking dashboard lights, erratic idle, my car is possessed!
    By aberabee in forum 1988 - 1994 (E32)
    Last Post: 10-27-2009, 04:48 PM
  3. Interior Dashboard Lights on When Car is Locked and Off
    By Smolder in forum 1988 - 1996 (E34)
    Last Post: 05-11-2008, 12:58 PM
  4. dashboard lights
    By jorre in forum 1991 - 1999 (E36)
    Last Post: 05-15-2004, 06:41 PM
  5. Replacing dashboard lights
    By kodachrome in forum 1991 - 1999 (E36)
    Last Post: 01-03-2003, 03:14 AM
