My valve seals are leaking and when my car idles for a bit, a huge plume of smoke starts. I had read that using Seafoam in the oil tank will lubricate the seals and correct the problem at least for a while. Replacing the seals ranges from $2500-$5000. Any thoughts on the use of Seafoam in the oil reservoir and procedure in doing it? Thanks!
Try using the 10w60 oil it may reduce the smoke
Thanks for the info!
