Bavarian Soundwerks
Results 1 to 4 of 4
Thread: Running sub and amp off a HU with only 2 outputs
    Jan 2018
    Sydney
    1994 BMW E36 318is
    Hi everyone,
    I have a kenwood KMM-X50BT head unit (came with the car) which only has outputs for the front and rear OR sub. I recently bought an active sub, some speakers, and an amp for the speakers (was a used bundle for very cheap, but everything works). Is there any way for me to set up the speakers and the sub from the same output? Could I split the output and send it to both the sub and amp and just use the lpf on the sub? Or does the HUs output setting (rear or sub) change the signal it outputs.
    If you need me to provide anymore info I'm more than happy to.
    Cheers,
    Prawnflakes
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    I checked the owners manual. The head unit has outputs for the front speakers, and rear speakers or a sub.
    Here’s the manual: http://manual.kenwood.com/files/GET0993-001A.pdf
    Jan 2018
    Sydney
    1994 BMW E36 318is
    Yeah but the point is I have 2 sets of rear speakers I need to send output to, the sub and the speakers. should I just connect the second set of rear speakers to the front output? Or do I need to purchase a new HU with seperate rear and sub outputs.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Connect the rear non-sub speakers to the head unit. Then, tap the wires going to those speakers and run wires to a sub amp that accepts speaker level inputs.
  1. Sub and Amp in the X5 with stock door speakers???'s
    By Bmwman528e in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-27-2012, 04:19 PM
  2. Running subs and amp on stock hu
    By hipe87 in forum 1988 - 1996 (E34)
    Last Post: 07-06-2009, 07:58 PM
  3. Help With Sub and Amp!
    By CuhCrack in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 05-28-2005, 11:40 PM
  4. Subs and Amp with stock head unit?
    By AlexThor in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 08-11-2004, 02:43 PM
  5. Subs and Amp work with Stock Head Unit?
    By BimmerDawg in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 12-18-2003, 06:35 PM
