Hey guys I have a question about my cylinder head timing marks I have the head off and I was evaluating my marks there is the factory mark on the head with the red circle in the picture attached and then there is what I believe is the factory mark on the cam with the blue circle but then there’s another Mark that’s was highlighted with white paint in the past sometime with the yellow circle which Mark is the correct Mark for the camshaft timing?
Dave
2004 525i Sport, Manual - 1985 325E Coupe Manual
Double check the crank - make sure that is lined up also - this will verify that the camshaft timing mark is in the correct spot (as Tomstin posted).
