Results 1 to 4 of 4
Thread: bmw e36 error code? inpa
    Nov 2016
    texas
    1998 328is
    i just scanned my cars ecu with the inpa software with dcan cable and i got error code 74 for the ac compressor relay which i unplugged to see if it will throw code and error code 225 and 226, which i did not intend to happen, it says its something about bank 1 and 2 cat effecicency? is this meaning either the cats are not efficent or the 02 sensors after the cat are not good? i was fixing to replace my pre cat 02 sensors since i feel some hesitation when flooring hard and have high fuel consumption. idk i cleared these codes and the 225 only comes back when im driving the car real hard. no check engine codes tho unfortunately. i dont know what else it is the car is real sluggish on the acceleration takes alot of gas, revs down pretty slow but i dont know which dumb sensor it is. i looked at the lambda 02 sensor but not sure how to identify if some sensor is not in correct working order
    226 is not in this screenshot for some reason, but i did receive it.inpa code.PNG
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
    Jun 2010
    NY
    1997 328i
    Replace your pre cat sensors. If you want you can put your old precat sensors in the post cat spots.
    In inpa you can watch the sensors to see if they are still switching.
    Nov 2016
    texas
    1998 328is
    I think my pre cat 02s have different part numbers for my 328i are they interchangeable
    Jun 2010
    NY
    1997 328i
    New ones are the same part number. But old/original ones may be a different length. So buy two new ones for the front, then use one of the ones to follow to the rear sensor to see if the length is good.
  1. E36 error code question
    By Abiondo in forum 1991 - 1999 (E36)
    Last Post: 07-26-2007, 11:21 PM
  2. E36 error code question
    By Abiondo in forum 1975 - 1983 (E21)
    Last Post: 07-24-2007, 10:45 PM
  3. FAQ: E36 Error Codes Misc Years
    By rocket859 in forum Wheels and Tires
    Last Post: 12-04-2006, 05:58 PM
  4. 1992 BMW E36 color codes?
    By caper in forum 1991 - 1999 (E36)
    Last Post: 09-22-2005, 08:58 PM
  5. BMW E36 Defect Codes/Dealer Codes
    By Jetfire in forum 1992 - 1999 M3 (E36)
    Last Post: 10-24-2002, 11:56 AM
